996 GT2/GT3 Forum 1999-2005
996 Gt3 2gen Pccb to steel conversion
Old 05-06-2014, 05:53 AM
Mikkofin
Mikkofin's Avatar
Default 996 Gt3 2gen Pccb to steel conversion
Hi,
My friend has a 996 Gt3 2004 with PCCB and is looking for steel replacements for worn out PCCB discs.
Are there direct replacements that fit from other Porsche models (Like 997TT, Cayenne, Panamera)?
We are looking for a cost effective solution so floating / aftermarket race discs are out of the question on this.
Thanks!
Old 05-06-2014, 10:31 AM
993GT
993GT's Avatar
Some common selections,
Front:
996Cup fronts
996GT3 fronts
Cayenne 350mm fronts
997.1GT3 350mm fronts
Rear:
997TT rears
997GT3rears
997Cup
Panamera Turbo 350mm rear
I converted my GT2 to Cayenne ATE discs up front and 997.1GT3 rears.
Cheers,
Old 05-06-2014, 10:48 AM
Mikkofin
Mikkofin's Avatar
Thanks for the reply
So, we could fit:
997.1 GT3 350mm fronts OE numbers 99735140990 & 99735141090
997.1 GT3 350mm rears OE numbers 99735240502 & 99735240602
directly without adapters or such to a 996 Gt3 Gen2 with the original PCCB calipers ?
I think these would be the easiest discs to acquire.
Thanks!
Old 05-06-2014, 11:00 AM
993GT
993GT's Avatar
Exactly,
Direct bolt-up using the stock 996GT3 calipers and pads, the PCCB pads work really well on steel brakes IMO.
-Rob
Old 05-06-2014, 11:10 AM
Mikkofin
Mikkofin's Avatar
Ok. Very good!
Because today we did notice that 997 Turbo front 350mm disc is different offset by maybe 2-3mm.
Rear supposedly is the same 997 Gt3 / 997 turbo.
Old 05-06-2014, 11:14 AM
993GT
993GT's Avatar
Yup the Turbo's run a different front offset then GT's.
Rear GT3/TT IIRC has a different part number but is essentially the same disc.
Old 05-06-2014, 11:15 AM
Mikkofin
Mikkofin's Avatar
Thanks for all your help! Appreciated
Old 05-06-2014, 11:17 AM
993GT
993GT's Avatar
Old 05-09-2014, 06:29 PM
ron_dargenio
ron_dargenio's Avatar
I just did the conversion with 996GT3 fronts and 997TT rear rotors, it was a simple straightforward job.
Front:
996Cup fronts
996GT3 fronts
Rear:
997TT rears
997GT3rears
997Cup
Cheers,
Quick Reply: 996 Gt3 2gen Pccb to steel conversion
