996 Forum 1999-2005
Ben's plenum
Old 11-05-2017, 05:45 AM
  #136
Ben006
Ben006's Avatar
Please explain what you mean by sitting flush?
Old 11-05-2017, 10:43 AM
  #137
tekkie
tekkie's Avatar
i assume the throttle body mount part is not completly flat? if thats it the best thing is probably to sand it down a little
Old 11-05-2017, 12:14 PM
  #138
HawkFan#12
HawkFan#12's Avatar
No, I am talking about the plenum itself. It is not sitting even on the left and right side where the rubber connectors are. I am sure it’s user error. I am going to give it a go today to see if any air leaks are detected, if not, I am not going to worry about it.
Old 11-05-2017, 01:02 PM
  #139
Ben006
Ben006's Avatar
When you fit the plenum, losen all 4 clamps as much as they can, it makes it way easier to fit and adjust.
Old 11-05-2017, 05:50 PM
  #140
HawkFan#12
HawkFan#12's Avatar
Thanks Ben. I will give this a try if I have to take it all apart again.
Old 11-05-2017, 07:58 PM
  #141
tekkie
tekkie's Avatar
yeah getting it all mounted is a pain in the rear, i had the same issue when i did my ipd one
Old 11-05-2017, 08:51 PM
  #142
HawkFan#12
HawkFan#12's Avatar
Well, went out and turned the ignition and it promptly dies before getting started. Guess I will start over next weekend.
Old 11-06-2017, 08:22 AM
  #143
Ben006
Ben006's Avatar
The boots can be hard to fit correctly... If you do like I said: undo the clamps to the max you should get more flexibility and be able to fit them correctly.
Old 11-06-2017, 11:40 AM
  #144
Mdnyte
Mdnyte's Avatar
HawkFan... one of the guys posted a series of pics with the IPD Plenum in Facebook Porsche 911 (996) page, take a look:
Facebook Post
then wiggle the other ends in and tighten.
Old 11-06-2017, 01:09 PM
  #145
5CHN3LL
5CHN3LL's Avatar
Be careful of the fittings on those boots...you don't want to tear or crimp a connector.
Old 11-06-2017, 03:25 PM
  #146
HawkFan#12
HawkFan#12's Avatar
https://www.facebook.com/groups/2464...60832/?fref=nf
Looks like the post was removed...a step by step DIY would be a good thing. 😜
Old 11-06-2017, 06:01 PM
  #147
Mdnyte
Mdnyte's Avatar
Its there if you do a search of the group....just search plenum. Keep us posted.
Old 11-06-2017, 07:33 PM
  #148
HawkFan#12
HawkFan#12's Avatar
which Facebook page, there are a number of them, never mind, I found it! Thanks for pointing me there.
Old 11-08-2017, 01:56 AM
  #149
HawkFan#12
HawkFan#12's Avatar
Ok so was able to get everything installed, tightened up, and the car fired right up. I will take it out for a drive tomorrow after work. Here are some pics. If anyone else is planning to do this, let me know if you have any questions.
Old 11-08-2017, 07:56 AM
  #150
Mdnyte
Mdnyte's Avatar
Where did you source the elbow? Does it fit well or is longer better?
Quick Reply: Ben's plenum
