996 Forum 1999-2005
blown engine
Old 11-23-2016, 06:44 PM
  #736
Slakker
Slakker's Avatar
Originally Posted by AWDGuy
so nothing I could have done other than stop the project dead in its tracks.
guess I got lucky.
It can sometimes be tough to discern between pride and ignorance.
Old 11-23-2016, 06:52 PM
  #737
rockhouse66
rockhouse66's Avatar
I can only imagine how satisfying it must be for you to be in the assembly phase after all your prep work. Hope all of the assembly continues to go smoothly for you.
So if the deck height is off, is that an issue other than the influence on compression ratio? Is it a valve clearance issue or ?? I know there is an ideal number but so what if it is off a few thou?
Old 11-23-2016, 07:07 PM
  #738
AWDGuy
AWDGuy's Avatar
sure but if deck height is off, I'm questioning a lot of other things with the parts at that point.
Old 11-23-2016, 07:11 PM
  #739
AWDGuy
AWDGuy's Avatar
pistons travel higher than the deck and make contact with the valves. buhbye motor
Old 11-23-2016, 08:34 PM
  #740
Ahsai
Ahsai's Avatar
I love Jake's analogy of building this engine (or maybe any engine for that matter). It's like the engine is trying to kill you (your wallet) so it's like going to war with it. Everything needs to be checked out. I'm big on sanity checks hoping to catch an issue before it can bite my ***. Essentially only the rods, crankshaft and its cradle are original parts (in the short block). The pistons, rings, pins, and the engine block are either aftermarket or machined so there are plenty of possibilities for issues.
One example is one of the second rings has some non visible burr on one of its ring ends. Not visible and you can barely feel it even if you know where to look. Once installed, the ring can't rotate freely. I was able to free it by dressing the end slightly.
Measuring the deck height ensures the pistons don't hit the head/valves like AwDguy said. Also it indicates all the mating surfaces are clean so nothing is stuck between them. Also, it let's you estimate the C.R. which is another sanity check.
Old 11-23-2016, 09:18 PM
  #741
Ahsai
Ahsai's Avatar
Thanks. Is it likely the sharp edges of the engine block/parts can catch and pull a fiber from the cloth inadvertently?
Originally Posted by JohnCA58
Sorry, should have mention what we use, large lint free shop towels, usually find 3 X 4 ft towels at the Linen company or even Huck surgical towels from company like this one, they are blemish but work.
http://raglady.com/Hand-Towels-Surgi...FQ6ZfgodA-cPZQ
Old 11-23-2016, 09:26 PM
  #742
Ahsai
Ahsai's Avatar
Default Marking the piston install tools
Tools needed to install bank 2 pistons. This is the same EWK tool I bought and found the delrin rod to be 3 thou fatter than it should be. After they held an engineering meeting reviewing the evidence and measurements I had submitted, they machined a new one to me to my specification and I returned the old one to them. It's a great company that's willing to do the right thing and help out the customers.
Mark the tool by putting a piston in the bore and mark it like the next photo right at the access hole
I used a gold sharpie
Old 11-23-2016, 09:42 PM
  #743
Ahsai
Ahsai's Avatar
Default Bank 2 case and pistons install
Cleaned the mating surfaces with carb cleaner and rubbing alcohol then apply Driebond. It's cool in CA here so it worked to my advantage (takes longer to cure so I had more time).
Bank 2 case installed
Bank 2 pistons with rings and one wrist pin clip (flywheel side) installed, ready to go
I used Jake's famous upside down gravity assisted method where you turn the whole engine so the bank 2 rods point to the ground. The other two rods #4 and #5 just got out of their way automatically! This is how it looks through the access hole, the small end hanging down
A view from the bottom
Piston installed and pushed UP to meet the rod small end
Piston and rod aligned
Wrist pin installed
Money shot! Wrist pin clip fully seated. It's a breeze after the practice in Jake's class.
Old 11-23-2016, 09:56 PM
  #744
Ahsai
Ahsai's Avatar
Default Short block completed!
3.8L Nickies short block
Old 11-24-2016, 06:57 AM
  #745
AWDGuy
AWDGuy's Avatar
oh man. so exciting. awesome pics !
Old 11-24-2016, 03:32 PM
  #746
JohnCA58
JohnCA58's Avatar
Assai, i have never had an issue with that at all, BTW great write up so far on the engine build.
Old 11-25-2016, 02:10 PM
  #747
Ahsai
Ahsai's Avatar
Default IMS Solution
The IMS Solution partially installed. Sorry can't get better pics as the engine stand mounting plate is in the way.
Flange installed
Ready to accept the IMS Solution flange
Oil fitting
Shiny pistons and deck
Old 11-25-2016, 03:50 PM
  #748
Schnell Gelb
Schnell Gelb's Avatar
Duncan, It would be interesting to see a photo of the 'plug' that seals the IMS tube. I doubt many Rennlisters have ever seen one.
Old 11-25-2016, 05:42 PM
  #749
Ahsai
Ahsai's Avatar
Sorry but mine came pre-assembled and I never tried to remove the plain bearing. That cover plate hides behind the bearing but my understanding is it's just a cap closing the ims opening so no oil can infiltrate the shaft.
Old 11-25-2016, 07:28 PM
  #750
Schnell Gelb
What ? You didn't dismantle it to polish it down to the last nano particle? LOL
Thank you anyway. And particularly for the best M96 rebuild thread by far !
Quick Reply: blown engine
