Today's Craigslist Finds...
#3271
A VIN so I can check if it had an accident of any concern. Usually just light bumper accidents which wouldn't both me, until I went to sell it. I have a Boxster that go bumped, got a whole new oem bumper out of the deal...to me it was great...now not so sure since no one will buy it.
This is the problem with insurance companies and carfax. Expensive cars often get totaled for minor damage because the repair cost is too high and you have the car mostly paid off. Then the title gets flagged as salvage or carfax notes the wreck repair and now no one wants the car. I am in this very dilemma with a 944 turbo. The car runs and drives well. It has very minor front end damage. It did get a new hood and the front bumper was pushed down and rear slightly. The original wreck damage can be seen on the front fenders (not replaced) and it is super minor. Car got flagged with a salvage title then "rebuilt" and sent to Michigan. I bought it in TN with a "clean" title. I'm not sure what TX is going to do when I try and reregister it. I'm tempted to sell it at a loss because restoring a "salvage" title car would be a bad investment even though it's overall a really good candidate to restore.
#3272
#3273
I need to say something about IMS and RMS. These problems occur in a minority, small minority, of Porsches. The IMSB fails in less than 5%. That's 95% of cars from the period that won't have a problem.
In the 1980's everybody shunned the 1975 - 1977 911S cars because of "weak engines" and unspecified "engine problems" Now, they are priced like unobtainium.
I had a 97 Boxster, arguably the most likely to experience both problems. I drove it like I stole it; seriously seven or eight track days per year where the car was consistently taken to it's limits. I just kept pushing until the car, more likely the tires, couldn't handle it anymore. Never had a problem to 45K.
I then bought a 2002 Carrera and drove it a little softer to 60K, no problems.
I now drive a 2009 997.2 C4S and the worry du jour has not crept up yet.
In my mind, were I to buy another pre-09 Porsche susceptible to IMS and and / or RMS, based on my experience, and the actual experiences of others, I don't know that I would rush to implement a fix.
I did notice my concern level rising the more I read blogs where people fixated on the IMS. But, what's most interesting to me is that many people on the blogs who are so fixated, have never owned one of the "afflicted" Porsches, or even a Porsche at all.
Its is important to note that the Porsche IMSB failure rate is less than 5%. There are a whole lot of Porsches out there that have never experienced a failure.
Ours is 2002 C4 Tip, we're 3rd owner and up to about 88k miles now without issue.
They (dealer) also mentioned that of all the cars they have ever serviced none of them were a Tip so we may have that going for us in the long haul. I was initially worried about it when we got the car in 08 (with 30k on it), but after 9 years and learning more I don't think we'll ever have an issue.
#3275
Shameful Thread Killer
A 5% failure rate, is just over the 3rd sigma(area under the normal dist curve) and in modern production environment would be considered a disaster. It would, and should have been a recall event, with Porsche removing every engine from production and putting a halt to deliveries until the problem was understood, quantified, engineered, tested, re-quantified and then released to the gen public. This could(and should) have been done in later 99 or mid-2000 when the number of failures in Boxsters began to be noticeable.
The solutions we have today could have been implemented, and a solution developed fairly early in the production cycle. That was the right thing to do, and Porsche failed miserably, resulting in the issues we are now living with some 20 years later(in terms of the M96 engine in total). It's a huuuuuuuge black eye for a statistical analyst at Porsche, who knew but was likely overruled by a 'crat with a econ degree.
Finally(I hope), there is NO engineering, or econ excuse for a 5% or even a 1% failure rate in any modern engine component. If that happened to Toyota or Mitzu, whomever was responsible would be run out of town on a rail, and fishing in the sea of Japan for squid for the rest - of - his - life.
/rant
#3278
Yes according to the work of Deming and Shewart the acceptable failure rate for manufacturing should be on the order of 1 in a million. That's actually a design criteria now for many companies. It's what made Honda and Toyota so successful and durable. It seems like Porsche had a pretty reasonable solution originally (double row bearing) but changed it due to supply issues which led to a fiasco. Having a part fail can sometimes be okay (i.e. if it is a designed wear items like a brake pad, clutch disc, or tire), but having a part that will fail and then destroy your entire engine is definitely not good for business or the customer.
Knowing the risk, I'm about to buy a 996 myself. It's already had some IMS bearing and RMS work performed. How long will that hold up? I'm gambling that it will last a really long time.
#3279
Former Vendor
Who did the work, and what retrofit kit was installed? This means everything in regard to longevity and reliability.
#3280
'99 roller sold for $8,200 on eBay:
http://www.ebay.com/itm/1999-Porsche...-/182537110683
Seems high to me, but -- as Mrs. KoB regularly observes -- I've been wrong before.
#3282
LN engineering dual row into a '00 at 73k miles done by Hindson in KC. I guess they didn't test drive this car much..... since it's just a plain '00 Carrera.
I went to your website and found it interesting that you don't do turbo builds due to compression issues, etc. How do you feel about the OEM turbo flat sixes? This might go in a different topic...
#3283
Good/clean looking 4S with 65k miles for $26k from a BMW Dealer
https://www.cars.com/vehicledetail/d...2581/overview/
#3284
#3285
20k for a 4s with only 47k miles?
https://santafe.craigslist.org/cto/6074519060.html
Can we do this game that if you buy a car posted on here you have to offer a 6 pack of your favorite local beer to whomever posted the link?
Just an idea
I like beer
Just an idea
I like beer
PLEASE CALL FOR DETAILS- is usually a red flag for me (100% proven by experience). Details will include..."A/C needs recharge", "runs great, but slightly overheats", "run perfect, but...reverse doesn't work", "runs strong, just has slight knock. Could be minor, but have no time to find out", "This is my brother's car, and he has a title. I will write you a bill of sale though", "CEL is on, but not sure why. Can't pass emissions. So I decided to sell".
NEW IMS BEARING- as key details is not reassuring either. Bearing was failing and got replaced? Why make the note of that one mechanical part?
