996 Forum 1999-2005
Hazard Trim Phone Mount
Old 03-05-2022, 05:29 PM
  #31
Scrh1
Scrh1's Avatar
Ball mount vote here too! Count me in for 2 of them if you decide to make them. Thx! - scrh1
Old 03-05-2022, 05:30 PM
  #32
sweet victory
sweet victory's Avatar
Originally Posted by yaz996
Thanks. Switched to a headless Bluetooth system. I'll share those details in its own post, but that's what sparked the inspiration behind this mount.
Ball mount is on the printer now.
That sounds awesome. Would love to learn more
Old 03-05-2022, 09:46 PM
  #33
yaz996
yaz996's Avatar
17mm ball mount with USB-C cable pass through is complete (with the exception of an outer edge filet that I forgot on this version). The ball/extension is reinforced with an M5 screw.
I'll be traveling for the next couple weeks. In that time I'll order a couple Magsafe mounts so I can confirm fitment and more print material.
The following 5 users liked this post by yaz996:
Coussa (03-07-2022), Jefe13 (03-07-2022), ScottBLEGO (03-07-2022), TheUnscented (03-06-2022), Type65 (03-05-2022)
Old 03-06-2022, 01:32 AM
  #34
TexSquirrel
TexSquirrel's Avatar
Received 2,425 Likes on 1,290 Posts
Definitely in for a ball mount.
…and a Second one for the Solo mount.
Old 03-06-2022, 11:31 PM
  #35
KellyMN
KellyMN's Avatar
That looks awesome! I’d have one when they are ready!
Old 03-07-2022, 11:49 AM
  #36
Coussa
Coussa's Avatar
Originally Posted by barbancourt
What would also be nice is a discreet hole that could be used to route a cable through it for MagSafe wireless charging mounts. Then we can hook up the wiring behind the dash for a clean install.
Wow, the USB-C cable hole is such a sweet bonus, fantastic idea!!!
I can't wait to order this.
barbancourt (03-09-2022)
Old 03-07-2022, 08:00 PM
  #37
ScottBLEGO
ScottBLEGO's Avatar
This is great! I am in for a ball mount. My preferred mount uses a slightly smaller ball, but I am guessing it may work with this ball. One other thing you might consider before production, what if you had a common trim mount, then different attachments based on what one's preferred mounting is? That would give you a two-part but much more adaptable product. Just an idea.
Old 03-07-2022, 08:53 PM
  #38
yaz996
yaz996's Avatar
Definitely considering the options via adapter route. That was actually what I did for my first design on the 17mm ball mount (see below). Doesn't look as clean unfortunately. My plan (and I want to hear feedback on this) is to offer a few different options that are all 3D printed but application specific. If volume ever justifies switching to injection molding parts, I'd offer a free replacement to all prior purchasers.
The following 4 users liked this post by yaz996:
ChuckUFarley (03-07-2022), plpete84 (03-08-2022), ScottBLEGO (03-07-2022), TheUnscented (03-07-2022)
Old 03-08-2022, 10:09 AM
  #39
Coussa
Coussa's Avatar
Personally I don't mind either option as it will normally be hidden behind the actual mount anyway. Ultimately I think the price will be the tiebreaker if I was to vote on one option over another. That's my 2 cents.
Old 03-08-2022, 12:12 PM
  #40
sp1ke
sp1ke's Avatar
One more tweak you may want to consider: if the section with the mount could be extended further to the right, to make the whole thing more of an egg shape, then the mounted phone would be in a more offset position. This could give greater access to the hazard light button. If the gap between steering wheel & phone is a little larger this may also be a better position for the phone.
FWIW I'd consider one, if you could make them in a darker black finish & suitable for a RHD (UK) car.
Old 03-08-2022, 12:33 PM
  #41
golock911
golock911's Avatar
Late to the discussion again. Looks fantastic. I haven't bought a mount yet because none seem to put the phone in a decent spot. I don't like sticking stuff to the dash, so those are out. Count me in, one of each type!
Old 03-09-2022, 12:34 AM
  #42
Porschetech3
Porschetech3's Avatar
Received 4,629 Likes on 2,100 Posts
BTW; just measured the ball on my phone mount, it the standard .669in 17mm size..
Old 03-09-2022, 02:06 AM
  #43
Flyfishnick
Flyfishnick's Avatar
I'm in for quadlock if you go that route. I hate playing with my *****, lol.....(sorry, had to ..)
Old 03-09-2022, 02:10 AM
  #44
Idaho911
Idaho911's Avatar
I'm in for a quadlock!
Old 03-09-2022, 11:46 AM
  #45
davidpg
davidpg's Avatar
I'd be in for some *****!
Quick Reply: Hazard Trim Phone Mount
