Unfortunately I don't have any prototypes ready yet. I was trying to get something done while out on paternity leave from my day job, but the return to work snuck up pretty quick.
I installed mine over the holidays - fantastic design, holds my phone in the perfect location that I'm returning my CarPlay HU since I can easily see my phone while driving for directions
Big thanks to Yaz for shipping so quickly to the UK. Received RHD version yesterday (no extra taxes to pay on import) and installed last night in about 5 minutes flat! Need to route the wire a bit more thoughtfully but the part itself is spot on 👍🏻.
YES! Its perfect for WAZE directions. I had a carplay unit as well and first attached it to to this hazard mount but dont need it as the phone is big enough and I bluetooth to the MR12VOLT
Ordered a mount today and a switch USB module. Super excited! Didn’t realize leaving our rennlist info was a thing, but I would be the order going to Des Moines!
Hmm… So, I installed everything and used the Rennline mount even though it wasn’t highly recommend. I thought that it was the best looking MagSafe charger, but the phone does tend to fall under acceleration + bumpy Midwest roads.
So, I ordered the ESR mount and it seems that I can’t the ESR charger tight enough to the 17mm ball - even using the included rubber insert. The plastic nut is as tight as I can get it and the ESR charger still moves around quite easily. There’s no way it can support an angle with my iPhone 13 Pro Max on it.
I wonder if there’s a variance on the ESR mount itself. I have a 14 Pro Max and it is pretty sturdy on the mount the plastic nut on the back of the ESR is tight.
