Ultimate Integrated Dry Sump UIDS v2.2
#121
Skip, any current updates?
Justin76 (08-09-2021)
#124
George has been back at it, it is on its way to me now to final assembly, inspect, one last flow test, then onto Sally's engine it will go...
Stamp for making screens for pick-ups
stamped screen, still needs framed
bottom covers done in "Cotes de Geneve"
#125
Update..
Everything on it's way to Skip. My part is done for now.
I apologize if seems that the project isn't moving at a quick pace, but I've done far too many projects at someone else's (rushed) pace. This project deserves the time and effort to be done properly.
Porschetech3 (08-24-2021)
#127
Continued thanks to you and Skip for your untiring, and public, work for these cars.
The following 4 users liked this post by golock911:
#128
What surface finish and coating would give the least thermal resistance to air? That surface has some amount of air moving across it. It would be good, if not cost prohibitive, to create a surface that would more easily give away some heat the air moving across it.
#129
Yes, please be patient, once the flow volume test and the pressure drop tests are completed, things will move along very quickly
The following 9 users liked this post by Porschetech3:
996fried (08-25-2021),
dporto (08-25-2021),
george_west (08-24-2021),
jobyt (08-24-2021),
JohnCA58 (08-25-2021),
and 4 others liked this post.
#130
Probably a standard Mil-Spec Hardcoat anodize would be the best option, type II or III. We utilize this on a lot of the aerospace components we manufacture, most all of which are fluid motion and transfer for fuel delivery, and fuel pumps themselves. Generally the coating itself is more for corrosion resistance and to create a surface harder than tool steel for added wear properties. Having this done would help slightly with heat dispersion, but only to a small degree. Surface finish would have a greater impact, which is why on a larger scale, heat sinks (veined material) do so well at heat dissipation, the same can be said on a microscopic level, but to a smaller degree.
The following 3 users liked this post by Billup:
#132
Probably around an hour of cutting time for the sump plate alone. Machining technique for making one of something is different than machining ten or a hundred. The cost/benefit of me tweaking the machining method to reduce the cycle time pays off much more as quantity increases. Tweaking process is never really finished. Always an improvement can be made on the tooling and machining method or workholding method, especially as new technology emerges or becomes accessible/affordable.
The following 4 users liked this post by george_west:
#133
The following 2 users liked this post by GC996:
Mike Murphy (08-26-2021),
Porschetech3 (08-26-2021)
#134
Porschetech3 (08-27-2021)
#135
I'm just super impressed how transparent you guys have been on the idea, the prototype MFG and how you think it will work.
It's a hard problem and for you guys to give some of the M96 folks that work the cars hard hope that a solution to such a long standing issue is in the works with the level of transparency you have really shows your commitment to get it right.
The following 9 users liked this post by zbomb:
Billup (08-27-2021),
dporto (08-27-2021),
frederickcook87 (10-17-2021),
GC996 (08-26-2021),
golock911 (08-26-2021),
