996 Forum 1999-2005
Another one bites the dust.
Old 03-01-2024, 05:59 PM
  #646
Siberian14
Siberian14's Avatar
Smile
Originally Posted by De Jeeper
Well i knew it couldnt be that easy.
The trans is held in by 4 studs and when i was torquing 1 of them stripped out of the block. I get to pull the trans back oit to heilcoil the hole. Yea me.
FWIW if you don't know about:
Helicoil is old and crappy. A Helicoil is just a wound spring that fills grooves, is not strong in a linear sense. There are German (I think, dunno for sure) things called "Time-Certs They are and actual solid zig-zag metal part (steel I think). part. One drills out the "hole" with correct size drill that also cuts a small "ledge" for the Time-Cert. Then you "tap" the hole with a Roll Tap that bottoms out. The insert is put in the threaded hole and the roll tap releases the Time-Cert at the bottom, comes out and hooray. it is almost as good as new and waaay better than a Helicoil. I have a box kit, say 4"H x 16"W x 12"L that has sizes from 4mm to 14mm diameter studs. It has been really handy to have at times exactly like what your trans bolts so graciously offered for you to fix.
JMO and thought. No offense if you already know about it, blh, blah, blah.
I have used these Time-Certs for years fixing pulled studs and whatever on Porsche aluminum parts.
YMMV
PS Exhaust looks great, but.... you can't put a trailer hitch on now!
Old 03-01-2024, 06:30 PM
  #647
tommelton
tommelton's Avatar
It's Time-sert... https://www.timesert.com/
Old 03-01-2024, 06:32 PM
  #648
De Jeeper
De Jeeper's Avatar
Received 3,461 Likes on 1,822 Posts
Well the timeserts were not available at the time and since i have done over 40 track days since that repair im 100% certain the heiciols r adiquate.
It the motor even needs a rebuild the machinist can fix it properly
In other news i have done some upgrades this off season. Upgraded the rear lca with tarret uniball units and the front got Rennline arms due to a screaming deal on a barely used set. Also working on cleaning up the bumpers, i really hate bodywork.
The other 2 upgrades are a new rs style cage that bolts to the floor and a Sabelt halo seat. Both used but in like new condition.
The following 5 users liked this post by De Jeeper:
GC996 (03-01-2024), gtxracer (03-02-2024), JohnCA58 (03-01-2024), Porschetech3 (03-01-2024), zbomb (03-01-2024)
Old 03-01-2024, 10:54 PM
  #649
De Jeeper
De Jeeper's Avatar
Oh and this tonight. Front bumper is next.
Sprayed my track car bumper under my truck that i just got running after a motor rebuild. Kinda getto but i used a base and clear from a can. Its real automotive paint from napa that they put in aresol cans.
EVOMMM (03-10-2024), gtxracer (03-02-2024), JohnCA58 (03-02-2024), Norocehcap (03-02-2024), Porschetech3 (03-01-2024)
Old 03-01-2024, 11:12 PM
  #650
Porschetech3
Porschetech3's Avatar
Received 4,631 Likes on 2,101 Posts
That looks pretty good from a rattle can !!
Old 03-02-2024, 09:51 AM
  #651
Atgani
Atgani's Avatar
Huh, Helicoil old and crappy ?
Nothing wrong with Time-Serts, but they're not superior to good old-fashioned Helicoils, and they cost a lot more.
Porschetech3 (03-24-2024)
Old 03-09-2024, 09:00 PM
  #652
De Jeeper
De Jeeper's Avatar
Alignment time again. Went 3.1* camber and -1.5mm toe for the rear and 4.0* camber with +1.5mm toe in front. I wanted a little more camber in front but even with the tarett high camber uppers i maxed out the adjustment on the rss arms. There r some things i can do if i need more camber in the future. I was around 4.0* last year and the tire wear looked decent. I also spent some time and got the wheel base squared up. Porsche literature says wheelbase is 92.6" and since i pushed the fan assemblies foward 3/4" i streched the wheelbase to 93". Im hoping to keep the larger track wheel/tires out of the fender liners this year.
fazm (03-10-2024), gtxracer (03-09-2024), wdb (03-10-2024), yaz996 (03-09-2024), zbomb (03-09-2024)
Old 03-09-2024, 09:16 PM
  #653
theprf
theprf's Avatar
Received 1,845 Likes on 1,176 Posts
It's looking good, Aaron!
Old 03-09-2024, 10:04 PM
  #654
c didy
c didy's Avatar
Wizard. Once again.
Old 03-09-2024, 10:59 PM
  #655
De Jeeper
De Jeeper's Avatar
Originally Posted by c didy
Wizard. Once again.
Not really but thx. I bought that string kit used for $400 and had a local small shop machinist make the hub stands about $600. At $250 per alignment it doesnt take much to recoop your money expecially if u r adjusting for tire wear and upgrading components for the track. It still takes me.5-6hrs but its better then leaving it at a shop to pay good.money for what i can do just as well at home.
Old 03-09-2024, 11:59 PM
  #656
c didy
c didy's Avatar
And, do it the way you want not to mention riding herd on The overall suspension and car in a way that only you, as owner, has the capacity for. Who knows what the alignment guy sees or does during the process. And, By the time you take the car, drop it off, come back to retrieve it, and head home it's likely about a wash time wise. I'd say it's Smart money in your case for sure.
Old 03-10-2024, 09:28 PM
  #657
De Jeeper
De Jeeper's Avatar
More prep today. I got the new rss roll bar in. Its made like the rs cage and it bolts through the floor. Its real nice for tall people like me too because the b-pillar sits tight to the step up for the back seat and not the seat belt bolt.i also got the new Sabelt halo sest installed but misordered the extension for the ohlin **** to the pass seat stays out for now. The seat is pretty tight and maybe a holo wasnt the right choice but man this seat is comfy and nice.
golock911 (03-11-2024), JohnCA58 (03-11-2024), plpete84 (03-11-2024), wdb (03-11-2024), zbomb (03-10-2024)
Old 03-24-2024, 12:32 AM
  #658
De Jeeper
De Jeeper's Avatar
Well since i spent a ton of time and some decent $ on fixing and respraying the front and rear bumper i am doing something i thought i would never spend money on.....ppf. it goes in wed for Expel-ing the front bumper, i just dont feel like doing the body work every year.
In other news i just passed my PCA national instructor class. Not sure how much instructing i will do but i figured i would give it a try. It may also allow me to do a few morw events because u get a significant discount as a reward for the work.
The following 9 users liked this post by De Jeeper:
allcool (03-24-2024), GC996 (03-24-2024), gtxracer (03-24-2024), JohnCA58 (03-24-2024), Norocehcap (03-24-2024), plpete84 (03-26-2024), ScottBLEGO (03-27-2024), wdb (03-24-2024), zbomb (03-24-2024) and 4 others liked this post. (Show less...)
Old 03-24-2024, 01:37 AM
  #659
Porschetech3
Congrats on becoming a PCA instructor !!!
The following 2 users liked this post by Porschetech3:
allcool (03-24-2024), wdb (03-24-2024)
Old 03-24-2024, 10:20 AM
  #660
Tom Loder
Tom Loder's Avatar
Welcome to the club, it can be really rewarding, and sometimes a little terrifying 💩
On the PPF, I’ve been told you need to let the respray cure for a few months before applying it. Worst case is it peels off the paint if you remove it.
Quick Reply: Another one bites the dust.
