996 Forum 1999-2005
What did you do to your 996 today?
Old 06-06-2023, 04:42 PM
  #8941
plpete84
plpete84's Avatar
Received 1,828 Likes on 924 Posts
I'd love to see light gold on your car. IMHO, I think black wheels get lost easily on the car from a visual perspective. I like to have some contrast between the tire and rim.
2mAn (06-06-2023)
Old 06-06-2023, 07:25 PM
  #8942
2mAn
2mAn's Avatar
Im not a fan of all black wheels, but I do love black wheels with a polished/ machined lip. I know Ive seen the Turbo Twists in black with a machined lip and it looked really good.
Old 06-06-2023, 07:27 PM
  #8943
SoCal911t
SoCal911t's Avatar
Received 1,474 Likes on 712 Posts
Originally Posted by Gregs04.5
I can either stay with gloss black, or now is the time for change, and I'm looking for ideas for color that would go well with the Paladium Metalic.(light gold)
I have some ideas, but lets hear yours.
TIA Greg
I would take the opportunity to change from all black, it's so played out. Check some of the picture threads here and on the 997 board for some ideas. Good luck with whatever you decide.
Old 06-09-2023, 12:38 PM
  #8944
cwbrown
cwbrown's Avatar
Default nothing
Did nothing to my 996 today, but I did take this nifty photo..
The following 4 users liked this post by cwbrown:
beermanpete (06-09-2023), imhighlander (06-13-2023), SARNODUDE (06-19-2023), TexSquirrel (06-09-2023)
Old 06-09-2023, 12:57 PM
  #8945
TexSquirrel
TexSquirrel's Avatar
Received 2,423 Likes on 1,288 Posts
Nice wing!
Mine is similar. (997 GT3-style base with 996 GT3RS carbon fiber wing)
Do you know the manufacture of yours?
Here's mine:
Old 06-11-2023, 03:23 PM
  #8946
hoofdpijn
hoofdpijn's Avatar
After staring at the parts sitting on the bench for a month I finally swapped these out. Wasn’t as bad as I thought it was gonna be.
Did Porsche put in Beru branded plugs from the factory or have these been replaced already? The coils are also stamped Beru.
damage98MO (06-11-2023)
Old 06-11-2023, 05:58 PM
  #8947
ssherman68
ssherman68's Avatar
I replaced the brake pads, mounting hardware dampers and brake wear sensors on all 4 wheels. Used the OEM Texar pads since everyone seems to like them for normal use. I measured the rotors a week ago and they're still in spec so I left those alone. Total cost $530 (those @$%&# dampers add up!) I also attempted to clean all the years worth of balance weight glue and God knows what else off the inside of the rims and applied a spray wax to them. The whole thing took about a week. I started last Saturday. When I saw how bad the wear sensors looked I ordered some (along with the dampers) and waited for them to come in before finishing up.
Some observations:
-It's amazing how quickly the second one goes after you figured the first one out. First corner on the front took almost an hour. The second about 5 minutes. Same for the rear.
-It's also amazing how easily you can put something in when you KNOW it goes there. I was convinced the 30mm shims on the back wouldn't fit into any of the holes until I did some googling & confirmed the 28mm goes on the top & the 30mm on the bottom.
-I don't think there is a product known to man that will remove all that old glue off the rims without removing the paint/clear coat. The wheel cleaners don't touch it, not even P21S. WD-40 and Goo Gone get about 75% of it off
sasilverbullet (06-11-2023)
Old 06-11-2023, 05:59 PM
  #8948
JMELZER
JMELZER's Avatar
I parked next to this GT4 - I think my car is faster now.
The following 3 users liked this post by JMELZER:
beermanpete (06-11-2023), golock911 (06-11-2023), maekwl (06-12-2023)
Old 06-11-2023, 06:04 PM
  #8949
RennPart
Basic Sponsor
RennPart's Avatar
I designed our wheel cleaner specifically to remove wheel weight old tape.
try it out guaranteed.
rennpart.com
The following 2 users liked this post by RennPart:
damage98MO (06-11-2023), ssherman68 (06-11-2023)
Old 06-11-2023, 06:15 PM
  #8950
wdb
wdb's Avatar
Received 1,232 Likes on 672 Posts
I use WD40 and a plastic razor blade thingie. Takes a while. Some staining can remain behind around the edges, but I get all of the adhesive.
Old 06-11-2023, 06:58 PM
  #8951
damage98MO
damage98MO's Avatar
L
Last fall I hit a set of rail road tracks that rattled my teeth, and apparently bending one rim near the core. I have 2 front rims on order, and will have them powder coated when they arrive.
So, my question for the forum is, I can either stay with gloss black, or now is the time for change, and I'm looking for ideas for color .that would go well with the Paladium Metalic.(light gold)
TIA Greg
@Gregs04.5 my cars meridian metallic. Here is a pic with silver wheels, and a pic w black. I have some bronze Momo heritage 6's on order. When they arrive, the twists are going to be refurbished and powder coated or painted, and I'm thinking a gloss black, as they were (I think) a factory option at the time. But I'm open to suggestions from the forum as well. Maybe Carrera red or yellow, something bold. Since my paint is so neutral pretty much anything will work. The renndecals Carrera decal can be changed easily as well. Though https://renndecals.com/ is down and has been for a while, Chris is still responding to emails at renndecals@gmail.com.
Greg what color did you end up doing? Light gold and dark 'blood' cherry red or crimson would be nice I think.
Old 06-11-2023, 08:24 PM
  #8952
sasilverbullet
sasilverbullet's Avatar
Some observations:
To get the wheel weight glue off I spray a little bug/tar remover (I use Tarminator) on a rag and rub hard. This should not take any clearcoat/paint off unless someone sprayed it with a rattle can. You'll have to rub hard, sometimes I use a piece of plastic. Just keep at it, it will come off.
Old 06-11-2023, 08:26 PM
  #8953
SoCal911t
SoCal911t's Avatar
Dang, I wish I had known. I have a set of Textar pads with less than 100 miles on them (too dusty for me). I would've made you a smokin' deal.
My '99 C2 left the factory with Bosch plugs and Beru coil packs. Porsche specs both Beru and Bosch for plugs so I guess it's possible they could have used either at the factory.
hoofdpijn (06-11-2023)
Old 06-11-2023, 08:32 PM
  #8954
sasilverbullet
Replaced my H7 standard Halogen low beams with LED's from Amazon. You have to buy the ones without the fan on top so it will fit.
Amazon Amazon
Old on the left, LED on the right.
Fits perfect!
Old 06-11-2023, 08:39 PM
  #8955
ssherman68
ssherman68's Avatar
rennpart.com
Thanks! I bookmarked the page.
Thank you for the tip. I'll keep the Tarminator in mind too.
Ugh! Oh well. I'll see how dusty they are. Someone put Brembos on the rears. The fronts looked like Texar but I notice the new ones have two metal cylinders on the top. Looks like they either serve as a heat sink or a wear indicator.
Quick Reply: What did you do to your 996 today?
