What did you do to your 996 today?
#5161
I don't mind changes that include adapters and other items that don't amount to much permanent change to the car. I'll set aside my original head unit that works. I saw that Crutchfield lists these Pioneers and many others as not compatible, but people are doing it. I assuming their criteria is fairly broad in that either they haven't tried it or more than the usual install work.
The following 5 users liked this post by autoRS:
Billup (04-26-2021),
Optionman1 (04-26-2021),
paddlefoot64 (04-26-2021),
plpete84 (04-26-2021),
user 8298308 (05-01-2021)
autoRS (04-26-2021)
#5164
Thanks for the compliment, don't go by this pic but bike is PTS in 356 Aetna Blue 😎
#5165
Another numeric pedal install. Took less then a hour on a y2k car. Only issue u had it snapped a little bit if the female ball socket on the gas pedal. Its still seated firmly and cant fall out so im leaving it.
The following 5 users liked this post by De Jeeper:
Billup (04-27-2021),
JBehba (04-26-2021),
NE1N-11 (04-26-2021),
TexSquirrel (04-27-2021)
#5166
Very cool steed and nicely put together!
The following 7 users liked this post by Nein96:
dcsjc (05-01-2021),
Mike Murphy (05-01-2021),
NE1N-11 (05-01-2021),
sasilverbullet (05-01-2021),
TexSquirrel (05-01-2021),
and 2 others liked this post.
#5171
Get yourself a good mechanics/detainers rolling seat because you’ll be there at least an hour. I used some ideas from the recent PCA Tech Talk video to get to the deep, or tight spaces. I started off with taking the air box out. This gives ample access to the engine front. I then used diluted Zep degreaser to clean whatever and oil or grease residue. I used numerous soft rags to wipe down everything, and leave no residue. Honestly, the previous owner took good car of the car, so there was minimum build-up. Once done, I used a soft bristled car detailing brush (one of many) dedicated for use in the engine bay to clean other localized areas not fully touched by degreaser. The soft bristled brush is key to getting most of the corrugated, raised, or depressed piping/tubing areas. I then used two ideas from the PCA video that talked about using chop sticks and bamboo cooking sticks to teach and get into the crevices. Using Aerospace 303 as a lubricant, I used the chopstick covered with a microfiber towel to clean all the difficult to get areas. THen the tight edges were reached with the tip of the pointed bamboo stick, without the towel. THe interesting thing brought up, that I also experienced, was the tip of that stick will fray slightly and act as a soft, but still rigid point. When all those deep, tight areas were cleaned I used a clean detainers brush and sprayed Aerospace 303 into the bristles and then liberally brushed everything down. Hopefully this provides some ideas to emply.
#5172
bmchan (05-01-2021)
#5173
You need some new floor mats! I have these and they are great - https://www.suncoastparts.com/product/SKU9X6RUBBER.html
#5175
thx joe, i do have similar rubber mats. Remember this car has over 200k miles so i dont think the carpet looks all that bad .
