996 Forum 1999-2005
What did you do to your 996 today?
Old 04-19-2021, 02:24 PM
  #5116
wyovino
wyovino's Avatar
Replaced some burned out bulbs in the 3rd brake lights (regular and spoiler). I had replaced one fixture when I bought the car 11 years ago because it was cracked. I held onto it and 11 years later I salvaged some of the bulbs. Sometimes things work out.
Old 04-19-2021, 04:26 PM
  #5117
bill_996
bill_996's Avatar
Default Paddle Shift mod
Originally Posted by nrp3
Took the car for some errands. Tidied up the garage a bit so I could get to the work bench. Started working on the conversion of a manual steering wheel to a paddle shifted version with the help of a couple of posts in various forums. Ended up looking pretty much the same, but when I went to test with one of my meters for continuity, whether the switch closed was dependent upon how tight the screw was turned and if I grabbed the top of the paddle, it didn't always make contact. Back to the drawing board...
I found that the paddles didn't have enough travel when I tightened the screw to hold it in place. I saw that others have filed off the metal on the back of the paddle (the pieces that protrude when the paddle is engaged). I tried gluing a small piece of plastic between those metal ends and it seems to work fine with nice solid feel. It creates a space for the paddles to travel without hitting the back of the wheel. Very happy with the mod!
Old 04-19-2021, 04:36 PM
  #5118
Boff
Boff's Avatar
Originally Posted by barbancourt
Looks good. I did this mod too, but you must have a weird anatomy to say you have more knee/leg room after doing this.
I’m 5’8” with short legs...I like to sit leaned back quite a bit and the wheel extended out almost as far as possible. I find my right knee is hard again the console at all times. Strongly considering this mod even though it’ll mean the end of my Rennline phone mount.
Old 04-19-2021, 05:00 PM
  #5119
nrp3
nrp3's Avatar
So, if you have your hands higher up on the wheel and just grab the top of the lever, it's shifting ok, ie switch makes contact. I have one I ground down the metal you mentioned, the other not. Maybe some more material removal might help with paddle travel. I'll work on it some more, maybe this evening.
Old 04-19-2021, 05:05 PM
  #5120
Boff
Boff's Avatar
Originally Posted by TulaneAg
Used a YouTube video of a British guy installing one from the wrong side. Happy with the look and additional knee room.
Is that a Function First shift **** on a short shift kit? Thinking of doing the same.
paddlefoot64 (04-26-2021)
Old 04-19-2021, 09:25 PM
  #5121
TulaneAg
TulaneAg's Avatar
Speaking for myself, it's really only a knee room problem on the track. I push my knee into the center console so hard keeping myself in place that over a full track weekend I'll end up with a sore and severely bruised right knee. I'm about to purchase racing seats and harnesses plus I made this mod to try and alleviate this problem once and for all.
Old 04-19-2021, 09:26 PM
  #5122
TulaneAg
TulaneAg's Avatar
That is a FF shift **** from Suncoast with a standard 996 shifter. I'm about to install a 997.2 GT3 shifter and Numeric cables next weekend.
Boff (04-19-2021)
Old 04-20-2021, 04:10 PM
  #5123
motoo344
motoo344's Avatar
First drive in weeks, perfect day to take a drive along the Deleware river. 73 and sunny, feels like we haven't had much sun here lately.
Old 04-20-2021, 10:16 PM
  #5124
yaz996
yaz996's Avatar
Had a little fun on the ride home along I-95. Black 991 Turbo S with a roof rack pulled along side and gave a big thumbs up. Then plenty of open road. My first time over 7k RPM.
The following 4 users liked this post by yaz996:
golock911 (04-20-2021), rx7dude (04-20-2021), TexSquirrel (04-21-2021), zbomb (04-20-2021)
Old 04-21-2021, 01:09 AM
  #5125
jobyt
jobyt's Avatar
Spring oil change.
Old 04-21-2021, 01:11 AM
  #5126
dantonio
dantonio's Avatar
Replaced the heater core. Was quite a straightforward job. Make sure to get the correct butyl adhesive tape for the foam cover.
Old 04-21-2021, 02:33 PM
  #5127
jamsam911
jamsam911's Avatar
I am going to replace my coil packs and spark plugs in the next 2 weeks on my also01 996, the car has 45500 miles on it, should I also be replacing the tubes? Thank you.
Old 04-21-2021, 02:37 PM
  #5128
wyovino
wyovino's Avatar
Yes, they're not expensive. Make sure to get the o-rings as well. Some places sell them separately, some include them.
Old 04-21-2021, 02:59 PM
  #5129
plpete84
plpete84's Avatar
Received 1,828 Likes on 924 Posts
My lower AOS flex pipe finally came in so I can finish the UAOS install. The new OEM one is actually flexible. The old one was super brittle and snapped in half but I guess constant heat cycles will do that to plastic pipes over 16 years!
Porschetech3 (04-21-2021)
Old 04-21-2021, 04:15 PM
  #5130
De Jeeper
De Jeeper's Avatar
Received 3,439 Likes on 1,804 Posts
Good luck fishing it through. Its a pita so consider unbolting the ac compressor to help
Quick Reply: What did you do to your 996 today?
