View Poll Results: Who's interested in 3D printed door pocket reinforcements?
Yes
![](https://rennlist.com/forums/images/polls/bar2-l.gif)
![](https://rennlist.com/forums/images/polls/bar2.gif)
![](https://rennlist.com/forums/images/polls/bar2-r.gif)
![](https://rennlist.com/forums/clear.gif)
70
95.89%
No
![](https://rennlist.com/forums/images/polls/bar3-l.gif)
![](https://rennlist.com/forums/images/polls/bar3.gif)
![](https://rennlist.com/forums/images/polls/bar3-r.gif)
3
4.11%
Voters: 73. You may not vote on this poll
Next 3D printing project.....Door Pocket reinforcements.
#106
"in" when you are ready to go to production and have a US mailing address. Thanks.
#110
Oh man that's really bad. Gmorat's plates plus JB Weld and paint would make it even better, but only if you are willing to invest some time......
#114
When I take off all the screws holding on the pocket to remove it, there are 2 different types.
1. Is a conical back headed screw used around the perimeter of the pocket.
2, A flat back headed screw which for me was in the position at the extreme end of the pocket, nearest the seatbelt mount.
I think that positioning is wrong and probably got switched around by accident. The flat back head should be at the mounting point at the handle. I think this is what caused a lot of the issues on mine. That conical screw really puts too much pressure on that area. The flat screw and a washer would be even better. Now i just need to identify that screw and then source washers to fit it.
G
G
#117
Took a look at mine (non-hifi) and definitely starting to crack. I'm in for a set.
#119
I'll start taking orders soon as I finalize the design and finish. I may supply the screws and washers as well so people don't use those awful wedge-shaped screws and crack these inserts also.
G
