View Poll Results: Who's interested in 3D printed door pocket reinforcements?
Yes
70
95.89%
No
3
4.11%
Voters: 73. You may not vote on this poll
Next 3D printing project.....Door Pocket reinforcements.
#153
I cannot get rid of the step in the overhang because the reason it is there in the first place is so that it doesn't interfere with the arc of the door handle as it is pulled. I checked it out this morning to try and figure out why it was there.
G
G
#158
In test fitting these pieces and looking at the differences between the different pockets I came to a realisation.
The shoulder on the mounted face side closest to the door handle has always been the same. It angles away to allow the door handle to rotate without any obstruction. The non-hifi version of the pocket WAS modified by Porsche to try and address this obviously known issue by making it twice as thick in width that it was previously. What they didn't address was that it all is still supported by one screw and the quality of the plastic which got brittle with age.
Probably not news to anybody else but it was interesting to me.
G
G
#159
I'm unclear on how this piece is installed. Is it installed over the broken piece and sistered into place with a longer screw? Or is the old broken piece cut out and the new piece glued and screwed into place?
Either way, I'm interested in replacements for both doors. Thanks for figuring this out!
#160
The blue tape in the second picture is just there to hold my cracked plastic together, in reality, that face will be butted against the plate on the back of the door handle.
#161
Slight modification to my non-hifi piece to try and fill the width at the top a little better. Also moved the hole about 0.5mm. I'll get a print tomorrow.
G
G
#162
Ah, I see. Will the overhang be enough to make the cover slightly ajar? Or act like a fulcrum on the hinge if you rest your arm on the cover? Or is it thin enough where it's not causing interference?
#163
G
