993 Forum 1995-1998
Turbo "S" Scoops with LED Lights Installed!
Old Oct 14, 2014 | 10:51 PM
  #31
Foxman's Avatar
Foxman
Originally Posted by Blitz128
Do you have a part number / order source for the correct Hella LED bulbs as I have non Led bulbs in the same housing and would like to change ? Thx
Type 911 UK appears to carry just the Hella "brake duct light" with 16 LED bulbs for 22 GBP each
http://www.type911shop.co.uk/shop/ar...6aid%3D2962%26
Old Oct 14, 2014 | 10:59 PM
  #32
Blitz128's Avatar
Blitz128
Foxman...Thank you
Old Oct 15, 2014 | 04:45 AM
  #33
911PERVY's Avatar
911PERVY
These are the LED bulbs in the lights, easily available in the USA surely?
http://www.type911shop.co.uk/shop/ar...6aid%3D8183%26
Old Oct 16, 2014 | 09:18 AM
  #34
tom97c4s's Avatar
tom97c4s
Price just $160 with bulbs http://www.ebay.co.uk/itm/2312841623...84.m1555.l2649
That link is dead
Old Oct 16, 2014 | 10:21 AM
  #35
911PERVY's Avatar
911PERVY
That link is dead
http://www.ebay.co.uk/itm/3313468877...84.m1555.l2649
Old Oct 16, 2014 | 01:56 PM
  #36
Busta Rib's Avatar
Busta Rib
To run your fog lights as DRLs, you can easily use a fused jumper on the relay. It is reversible as well. That is what I did. Check out page two of this thread for details: https://rennlist.com/forums/993-foru...s-done-it.html
Old Oct 16, 2014 | 02:41 PM
  #37
hn's Avatar
hn
Thx for the link. How did I miss that. I assume that this will only turn the fog lights on, no other lights?
Old Oct 16, 2014 | 04:51 PM
  #38
Busta Rib's Avatar
Busta Rib
Yes, this will only run the fog lights.
Old Oct 21, 2014 | 07:32 PM
  #39
hn's Avatar
hn
Got this done, Thx. Much better than before but just curious, is it possible to control the fog light **** independently from the head lights? in a way, able to turn the fog lights off from this mod.
Thx
Old Oct 22, 2014 | 03:25 PM
  #40
curve lover's Avatar
curve lover
To run your fog lights as DRLs use a fused jumper. Check out page two: https://rennlist.com/forums/993-foru...s-done-it.html
Jim-- IIRC Knight & 996 (Ray) had this slick mod at 993Fest & urged me to do the same.
Before starting my slide down the slippery slope:
LUV to see to see a shot of your or hn (Hoan)'s fused relay; looks like Olivier's photo is fuse-less:
Originally Posted by Cabarnak
Originally Posted by Ed Hughes
I think the procedure is for a fused jumper-yours looks to be a simple piece of wire.
I opted for a ghetto approach since my install is temporary.
Old Oct 22, 2014 | 05:28 PM
  #41
hn's Avatar
hn
I used the inline fuse holder made for auto and inserted an auto 30A (relay's rated for 40A) fuse in there. Plugged it straight into the slots. Thx Busta Rib for the idea. I'll take a photo tonight.
Old Oct 22, 2014 | 11:43 PM
  #42
hn's Avatar
hn
Old Oct 23, 2014 | 12:29 PM
  #43
curve lover
^^ Hoan ^^
Old Oct 23, 2014 | 01:48 PM
  #44
Busta Rib's Avatar
Busta Rib
Yep, I went to Radio Shack and bought something pretty much like what hn used. Really easy to cobble together.
Old Oct 26, 2014 | 03:21 PM
  #45
gmorat's Avatar
gmorat
The Hella lights are an incredibly tight fit!! Holy cow this is going to be fun.
My hellas came with a rubber band in each package which you have no mention of. It's not supposed to be a gasket or O-ring or something is it?
Great write-up.
G
