Use 2k clear coat When you spray it make sure you have a full can if spraying downward. Try to avoid spraying downward if possible. After your done you can color sand and buff to a factory finish. I’ve painted fenders etc with this method. It’s quite remarkable the finish you can achieve due to use of this product Gunar
Yes Sir, plug and play. The turbo scoops fill the hole where the fog lights go. Euro simply has larger turn signals fill the spot where the bumperettes lie.
These new Turbo Scoops from 911 are great. The price is largely the same, but now they include the wires with integrated connectors. Awesome!
