Base Carrera vs Carrera S
#286
I just read the last two replies to this thread, the ones before were on December 2023, and earlier. So excuse me if someone already mentioned the below information.
Although it is the same 3.0 engine, the S has PTV+ (Porsche Torque Vectoring Plus) while the Base only has a limited-slip differential, therefore, the S can deliver the power in a better way to the rear wheels.
The turbos in the S are larger than those in the Base. (Pic below) The S and GTS have the Same Turbo, but the GTS is tuned differently.
The S has a 6-piston caliper with 350mm disc brakes, while the Base has only a 4-piston caliper with 330mm disc brakes. The S can be configured with RAS (Rear Axle Steering) and PDCC (Porsche Dynamic Chassis Control) while the Base can not. Therefore an S with less power with PDCC and RAS might be able to perform better than a Base depending on the Tune Level.
Blueblazer (05-24-2024)
#287
#288
#289
While this is easily addressed with a tune, the last thing the car needs on the street IMO is more rear grip from a rear diff (or PTV). The Base C2 almost feels like you're driving an AWD car vs a RWD car
#290
Received 2,842 Likes
traction control is different to an LSD. Traction control in a 992, including the S, is done via the brakes. The base RWD car has an open diff, no LSD.
#291
Thank you for pointing it out, I went to a few other forums and you are right. But the question is, why would Porsche have a basic open diff on the Base, and add a PTV+ on the S?
The following 2 users liked this post by M3Inline6:
InfiniteSmiles (05-27-2024),
Jeff Whitten (05-24-2024)
#293
#294
I’ve had a base and currently have a T manual but was previously hell bent on an S. After realizing I wanted a less refined driving experience, the T was the right choice for an enthusiast spec of the litter. It’s nice to know the T will be more desirable than the S in the future as well.
#295
Porsche could have at least bridged the gap a bit between the two models.
#296
vg247 (05-25-2024)
#298
I'm not saying that the base should have the same specifications as the S. However, Porsche went with an Open Diff, not LSD nor even a PTV. The S has the PTV+.
They might have done that because if someone decided to tune the car the same as our friend here, they might get the same power as the S but not the same track performance.
#299
The S has so many advantages over the Base, with the RAS, PDCC, Brakes and others...
rmb1973 (05-25-2024)
#300
I've had other cars that have rear axle steering, torque vectoring, dynamic steering and all those other acronyms and I turn them off if I can. It numbs the driving experience.
If I wanted the fastest car, I could drive an EV like a Hyundai Ioniq 5 N and would feel like driving a computer game - with no soul.
I've thought about swapping my base for a S simply bc I'm hoping that the extra power will be enough to overwhelm the rear tires a bit more bc the base does not have enough power to do so. However, the simple fix is to add a tune to the base instead.
