Is anyone tuning the 992 yet?
#93
#94
Now there could be circumstances in which the tuning protection does indeed retard the timing/boost due to the knock sensor values being out of range. (not to the point of audible detonation) This would result in reduced power.
You can always ask the tuner to share data logs of the calibration and discuss their individual calibration strategy. Key taking point would be low speed pre ignition (LSPI).
#96
Every time the knock control system senses knock there is some amount of fatigue imparted into the pistons and other parts. At normal levels of knock control this is not an issue. However if the tune is aggressive it could massively increase the detection events for a given high octane fuel. The puzzle is if the engine is robust for some markets where the best fuel is 95 RON then it could be that the elevated counts with a tune at 98-100 RON may not be an issue.
There is no way around the elevated cylinder pressures adding to wear and fatigue on the engine. However, the wear with the tune driven on the street in the US may be less over 100K miles than running hard with a stock calibration on the unrestricted autobahn.
The risk all comes down to the exact tune and how you are going to maintain and drive the vehicle.
SBAD (02-04-2021)
#97
M-engineering offers a dyno based 992 tuning solution that is matched to your specific engine, ie NOT a "canned" tune. This allows AFR, timing, etc. to be custom matched for your specific engine. According to M-engineering this usually allows them to eek out +10whp compared to their generic "canned" tune option.
#98
I'll have this done in about a month Bigworm.
Ah! That's the ticket. I just keep seeing canned tunes being offered for the 911 and it just makes me wonder how every single engine just reacts perfectly to them. I would never slap a canned tune on my 911 unless I had logs. Especially on 91 gas! That's just crazy to me.
I'm happy to hear you are going the pro-tune route! That's the only route Id go.
#99
^exactly
They only charge $1k more for the custom dyno version so I figure what the hell. It should be safer for the engine, it might make a little more power, and I'll have some dynos to see what my money bought me. My cat deletes arrive next week from Kline so its getting close!
BIGWORM (02-03-2021)
#100
Your 911 comes to you with a "canned" tune for a base model, another for an "S", etc. I've run canned, off the shelf, generic, tunes or whatever else they are called in many different cars for over 20 years and never had a problem. You want a calibration developed by well known, proven, tuners. A tune that takes your engine to the edge may not be best unless you are looking for a bragging rights dyno sheet. A local shop that hammers your car on their dyno machine all day extracting that last 10 HP or manipulating parameters to show same that you would never feel may not be the best way to go.
#101
^exactly
Keep us posted!
#102
#103
My point is simply If have the choice between a custom calibrated tune specific to my engine or a "canned" tune, all else being equal, I'll choose custom as it will be more dialed in.
And the reason M-engineering can generally eek out 10+ whp from a custom dyno tune is NOT because they push the engine to the ragged edge but rather the "canned" tunes they offer are conservative in all parameters to make sure they are safe for all 992 engines with varying tolerances. Another words they leave plenty on the table with the "canned" versions.
#104
People need to be aware that just slapping a off the shelf tune on any car without logging is crazy!
Reputable tuner or not. PERIOD.
And pro tuners typically do what the customer pays for. Most want reliable power. Some want bragging rights. That’s case by case. Either way I’d take a pro tune for reliability over an off the shelf tune every time and I suggest the others here do as well.
If the off the self tune runs great. Awesome! But I want to see logs. Regardless of how reputable the tune company or person is. And others who want a tune should too. Because without proof, your all drinking the cool aid and risking a very expensive motor based on what some guy with generic canned tune use said it’s fine. No thank you.
If you tune you get logs or you’re playing with fire.
SBAD (02-04-2021)
#105
This was not a "canned tunes suck" post. I've run several cars with "canned" or "off the shelf" tunes so in no way am I bashing on them. My 458 runs a "canned" tune from OpenFlash and its ran like a champ for 2+ years. My Z06 ran a caned tune for 3+ yrs @850hp...no issues.
ggreg911 (02-03-2021)
