Resetting Oil Change Reminder (after changing oil of course)
#106
If a tool is confirmed to reset the oil service, will it also do the additional service messages? For example I have two counters running right now, one for oil and one for a 40k mile service.
#107
PIWIS 3 does so as well as Launch IIRC
siberian
siberian
MattAlaska (01-22-2023)
#108
Received 2,687 Likes
#109
There are actually 4 sensors to check/reset as part of the SRI suite:
1) Inspection
2) Oil service
3)Engine oil
4) Gear oil
siberian
1) Inspection
2) Oil service
3)Engine oil
4) Gear oil
siberian
#111
Quick reply to msg #81
I own a 2017 C2S and have two sets of wheels and tires for it, the OEM set from Porsche and a set of OZ Racing wheels that I purchased in 2019 from Tire Rack complete with TPMS sensors installed and Michelin Pilot Sport 4s tires mounted [before Tire Rack had Porsche-endorsed "N" rating versions available]. I change these sets every spring and fall and don't worry about which tire and wheel assembly was mounted on the left or right. The Porsche system always soon learns of the change and updates. I do have to enter the data to indicate whether they are summer or winter tires and rim size [all are 20"] although the OZ front wheels are 9" wide vs. the OEM wheels being 8.5" and the OZ rear wheels are 11" wide vs. the OEM wheels being 11.5" wide, and for the summer tires if I am electing the Comfort settings which allow lower tire inflation pressures, and presumably activate an electronic speed limiter since Porsche says that speed must be kept below 165 mph with Comfort settings. I'm never going to have an opportunity to find out.
#112
What "features" are you interested in accessing?
siberian
siberian
#114
As far as the cost goes . . . . by the time I'd paid a dealer to do nothing more than reset the Maintenance Minders two times, I'd have spent more than the MK808S cost me.
#116
Good post, but to be effective you need to add something along the lines of
"pizza and/or beer provided...".![evilgrin](https://rennlist.com/forums/graemlins/evilgrin.gif)
Just saying...
siberian
Just saying...
siberian
The following 2 users liked this post by siberian:
Bluehighways (04-26-2023),
Humbucker427 (04-25-2023)
#117
#118
NEVER assume...
siberian
siberian
#119
#120
