OK can you be a bit vaguer please? What do you want to accomplish with this change? AFAIK, you can change region in VOF, and then? You can change your interior from leather to alcantara in VOF but that doesn't mean your seats will change which is why I ask.
siberian
so basically im trying to get navigation to work in my country. And also to activate wireless carplay.
Hello everyone,
I have set up a PIWIS III 41.500 in a VM and can already use it to read my two vehicles, a Macan S 2019 and a 992 C2S 2022. Thanks to the forum and its great members and the descriptions here, I was able to optimize a few small things.
But why I actually started the whole thing is that in Germany, for legal reasons, the flap exhaust is controlled in such a way that it automatically closes the flaps between approx. 30 and 70 km/h.
I know that on the Panamera, and probably other models as well, you can code a setting so that the flaps are always open as soon as you press the switch.
As far as I could research on the internet, the function on the Panamera is called "Geraeuschdaempfungsmassnahmen". There you can then select the values "170 - Akustikpaket RDW", "171 - Akusikpaket USA" und "172 - Akustikpaket PAP, CHina, Korea".
Unfortunately, I can't find these entries in any of the control units in my vehicles - but maybe someone here has already done this and can help me.
Many thanks for your help and sorry for my bad english
hello, how did you solve them by mistake. I deleted them, does anyone know how I can reactivate their driving modes
if you have deleted the codes , then you will be able to return the codes only through the online PPN service
you can contact Belauto, he can solve your problem https://mhhauto.com/Thread-Piwis-3-v...and-PT3G-V1-V2
I would like to see if mirror tilt with 4way SS+ can be enabled on my incoming 23 992CS. I missed speccing surround view and would like to have tilt mirror enabled.
I'm a Mac guy but I chickened out and got an ready to go V38.3+V41.900/Lenovo Yoga from vxdas.com for $1,161. PowerMax 100A was set to 14 volts. After a few tries I cleared the reminders. I forgot how slow Windows was.
Many thanks to all on this thread and the other PIWIS threads who shared their pain, joy and advise!
Reason: spelling
see John Mclane's original picture. I just had to search to find where it was located. Kombi and then "warning alerts"
I happen to change both of the alerts. I don't remember, but is there an alert that pops up for both occurrences? ie, airbag turned on when someone sits in the passenger seat? and airbag turned off when some sits in the passenger seat?
Originally Posted by John Mclane
Today I managed to get rid of the airbag activated/deactivated message...
Hello, have any of you had this problem? I try to activate the performance display, although the menu is displayed the content does not seem to be displayed... perhaps I forgot to activate a module?
However, I notice that all the data from the following modules (Performance and torque indication_0 & Performance and torque indication_1)
have X Axis and Y Axis at 0. Maybe that's what's wrong.
Module: Performance and torque indication_0/ Performance and torque indication-Performance
x(R-Min): value 0
x1 to x20: value 0
y(KW):value 0
y1 to y20: value 0
Performance and torque indication_0/ Performance and torque indication-Torque
x(R-Min): value 0
x1 to x7: value 0
Module: Performance and torque indication_1/ Performance and torque indication-Torque
x(R-Min): value 0
x8 to x20: value 0
y(NM):value 0
y1 to y20: value 0
Maximum RPM: value 0
retightening display time: value 1 sec
Do any of you who have successfully coded this display also have access to these values and can share them?
