Refinished Porsche Badge From "interestedparty" On eBay
So I got the badge from this seller due to some positive feedback on this forum. I go to install it, pegs are way off and the badge would not sit properly. That was delivered end of May. Seller offered the VHB Tape - I really did NOT want to take that route at the time.
I had to email sellers 3 times before getting a response, finally telling me to send the badge back. Was partially refunded a small amount for my troubles.
Radio silence...
about 14 days go by, and I finally heard back - seller stated he thought one of his employees was sending out the badge, they did not so they sent me a new one.
Again posts that go into the hood and secured by the nuts are in the wrong spots. I am furious.
I posted on the 991 Enthusiasts group on FB, and a few members are convinced its a fake badge.
Do the posts on a OEM badge need to be removed and rewelded during the refinishing process? Now Im starting to think it is NOT a genuine badge, even though it really appears to look like one, and the sellers states its genuine.
My problem? Being lied too. I will return it if so - only one solution left is to use 3M VHB tape.
I also want this thread to serve as a warning about dealing with this seller assuming it is incorrect listed as genuine.
The badge looks awesome and I would like to use it - so lets hear your thoughts !
I am not bad mouthing unless you guys tell me something isn't right here. Seller has responded and willing to send tape !
Link to purchase:
https://www.ebay.com/itm/20299502214...m=202995022149
Pics of 2nd badge:
Radio silence...
Link to purchase:
Pics of 2nd badge:
Looks very different. BAck and front. Looks great though. I just wouldn’t want to tape a badge on.
Sellers response about posts:
I can assure you that it is a genuine badge and any misalignment of the posts is my fault as I replace the factory mounting studs on all used badges we recondition with new, slightly larger, solid brass posts. The studs or posts are a notoriously weak point on the crest after it's been installed and subsequently removed. The only time we don't replace the mounting studs is when we've received a "never installed" piece in a core exchange or the purchase of a large number of NOS pieces.
I would do my best to make a template showing where your factory posts live relative to the badge. They should know exactly where the posts should be though. I would not be happy with the location of the badge within the depression in the hood. It should be damn near perfect.
Received 3,461 Likes
Many of us here with custom crests have used a piece of 3M tape on the back, in conjunction with the posts and nuts, and 3M tape alone will hold it in place all by itself. Here is an old thread for your reading, and viewing, pleasure: https://rennlist.com/forums/991/9086...placement.html
There are several more and if you search on "custom crest" you can read them. I used 3M tape on mine as well as the posts and original nuts with the rubber sealing washers:
LWG (06-19-2020)
Your badge is aftermarket and thats why it doesnt fit. has nothing to do with re welding any tabs, thats BS. Yes, the tabs are beefier, but thats because the Chinese factory that made it made them beefier.
The easiest tell is the art on the badge itself. If you look at the "leaves", the fake has all XL ends. The original has them gradating in size from small to large. The fake badge has them all way too large and even the remaining leaves on the branch are wrong size and shape. The badge isnt genuine, which is why you are having problems.
The following 3 users liked this post by PTS-BRG:
The seller used to be a forum sponsor here it seems years ago. Seems like a nice guy. Jim from Carrera East Studios.
It appears you are correct. It is a different part number, hence the difference in artwork. I also had Jim do my Badge and it seems it is exactly like your "bad" badge.
He is using service parts to make his custom badges and they appear to have different part numbers. I took a picture of the one Jim made for me and its the same as the one he made you and the same as Bob Z's...
Did you mount with tape? Looks nice!
Jim has made me 7 for my car and they are all perfect (frunk, wheels, steering wheel and an extra I put on the rear) and all are perfect. The extra was intended to go on the steering wheel but it was a little larger for my likes (same as the wheel center caps) so after some research I discovered the one used on the 356 would be better as it is a little smaller. Jim told me he could make it but it had to be an original and he said he will only refinish the 356 crests with a AR (Alois Rettenmaier) hallmark on the backside since the process he uses could ruin the cheap knockoffs (see below). I wound up buying a new OEM one and again, they are all perfect.
paddlefoot64 (06-20-2020)
If your first picture is the badge in question, that's because that badge was only used on 993, 996, and 997.1.
