DSC Sport V3 Control Module
#556
- if you want a more comfy ride than stock add the V3
-if you want a more precise handling car add the V3
-If you want to utilize the full opportunity of the your car add the V3
The car using the G-sensor and level sensors at each of the car’s corners to stiffen both the shocks and engine mounts to best control the car given the situation.
I have spasm in my car and at times the ride was just too rough... this v3 smooths out the ride quality and then can instantly turn the firmness to 100% (exaggeration) to deliver the performance that is being required. In summary if I have 10% lean in the car I am now between 2-3% lean with the unit installed.
Looking forward to sport mode and tracking it.
People have been bothering me for years to purchase this V3 unit... I should have bought this years ago. Worth every penny.
#557
I will let others explain the technical aspects, but for $1000-$1500 (whether you buy new or pre-owned) your car becomes a proper daily driver in "normal" mode and significantly better handling in corners in both Sport and Normal settings. I have a .1 GTS with S-PASM and even then the difference for me (at decent spirited speeds in corners) is night and day.
If you never really push the car much, it may feel like a small improvement, but start hitting some familiar roads and you will feel the difference right away.
#559
I like what I am hearing except for the comfy in normal mode. I have no issues with my T in normal mode or any other mode for that matter. Having said that, my T is not a daily driver and when I drive it I am perfectly okay with a ride that is not comfy. Sounds like a great addition overall.
#560
I wouldn't confuse "comfy" with "compliant". Some of the most expensive one-off super bike suspension I ever got for my race bikes (Direct from Ohlins) was way more compliant over bumps NOT comfy.
See a properly set up race car go over bumps in slow motion, it is undeterred by imperfections.. Its not comfy
V3 takes unnecessary harshness out of PASM , which I assume Porsche "Leaves" on the table for those who may confuse harsh/tight with Sport.
(Kind of how Starbucks over roasts their beans for those who confuse bitter with strong coffee.)
#561
^man lots of love here. I gotta bite the bullet and buy this sucker soon! Been following this thread for years and never bought it, even when one showed up locally. Shame on me (:
any warranty issues with the v3 dsc controller or do you guys just pull the controller when going in for warranty work?
#562
completely agree. Feels like expensive ohlins has been added to the car for normal driving.
The car now more appropriately reacts to road imperfections.
#565
Sarawnty (09-10-2021)
spyderbret (09-09-2021)
#568
The V3 doesn't exactly turn your dampers into TTX Ohlins, but it's a big improvement. There is sometimes some softness in normal mode, but it's momentary and overall vastly improves both normal and sport.
desmotesta (09-10-2021)
