DSC Sport V3 Control Module
#541
This is a tire choice problem, 4Ss are notorious for chunking on the outside edge like this, just not the right tire for aggressive track driving.
#543
#544
PS4S is a 360TW tyre. It has no business being on a track with a capable driver. Even a Cup2 is really a high performance street tyre . They are great once at the track and then they are destroyed. Rain grooves are too wide.
TrofeoR are track tires. 60TW. Much finer water grooves.
Cup2-R are the serious track tire.
The following 2 users liked this post by 4 Point 0:
spyderbret (09-09-2021),
vtgt (09-06-2021)
#545
^Makes sense thx
#546
It really comes down to how hard you are driving.
I am made to understand that the relatively soft springs fitted to a stock spasm car give up the available mid-corner camber settings and the tire eventually rolls, then loses contact, and beats up the outside edge of the tire.
the rest of the tire is basically fine and ready for another 4-5 days but due to the chunking on the edges the tire is scrap earlier.
I am aiming to extend the tire life without changing into a coil-over kit and changing out the sway bars. This is the first step goal with DSC.
I want to maintain the daily drivability as this car is my school bus.
Now... off topic...
What other tires can I run on my 4s without damaging or pre-maturely wearing the four-wheel drive system ?
I have specifically stuck with the Michelin PS4S (n rated tire) to keep the overall tire dimensions the same compared to stock so that the four wheel drive system does not freak out or wear out.
if there is no technical reason to stick to then n rated tire I am all ears.
Can/ Would the all wheel system accept a Treffeo R (or another tire different from n rated) without even caring about the minute differences in the tires dimensions?
...I cannot say I have come across any forum thread speaking about a failed or worn all-wheel drive system.
#548
I get maybe 5 track days out of my Cup 2s, and I’ve gotten about 6 track days out of my Dunlops (tried them because I couldn’t get Cup 2s). The Dunlops are 80TW, while the Cup 2s are 200TW or thereabouts, but remember that it’s not really easy to compare UTQG ratings betweeen different manufacturers, it only applies within a single manufacturer, so Dunlop’s 80TW may be pretty close to Michelin’s 200TW.
Right now I’ve maxed out my negative camber and have a track alignment - that, more than anything, has made a big difference to tire life. Prior to that, my 1st set of Cup 2s only lasted 2 1/2 track days. I have not noticed any difference in tire life since putting in the DSC controller - as 4 point 0 notes, fixing your alignment and camber will do more than the controller. While the controller itself definitely makes a difference in how the car handles on track, I’m not of the opinion that it will help with tire life at all.
vtgt (09-06-2021)
#549
I would be *very* surprised if the 4WD system cared one whit about what tires are on the car from a durability perspective. If you care about using N-spec tires (and there are good reasons w.r.t. tread compound to do so), then Cup 2s, Cup 2 Rs, Trofeo Rs, Dunlop Sport Maxx 2 Race, Goodyear Supercar F3 and some others all come in N-spec, and most of them *should* have sizes that you want.
#550
Just got my V3 today from a fellow Rennlist member, installed in 2 minutes and no lights errors etc. No need to disconnect battery.
There is nothing new I can say that other users havnt said already
Just took the car out of a quick 10 minute test drive. Very familiar back roads and a couple of butterfly ramps
Car is totally transformed.
in "normal"mode it soaks up bumps and road imperfections like never before. Even leaving the house the difference was noticeable within first 10 yards of driving.
In "Sport" mode the car is noticeably more agile, far less body roll (even though body roll wasn't much of a problem with Sport-PASM Suspension )
I have to say, initially in this short test drive, the biggest difference is how car stays flat near near "street limits". I wasn't paying attention to the speed and ended up entering a butterfly ramp significantly faster than I ever had and correcting the car so I could follow the line was easy, without drama and most importantly without any body roll at those speeds and G-forces.
The following 3 users liked this post by desmotesta:
#551
I installed my V3 on my 991.2 yesterday as well. Your summary above would be my summary word-for-word. The only thing I can add, but is implied in your summary above, is that the V3 DOES provide a VERY positive noticeable (and comfortable ???how....????) improvement to front end feel. For reference my car is a 991.2 4s with rear axle steering and spasm.
You can really lean on the front end hard during corners and breaking and trail breaking much more than before without any drama.
Amazing technology ...
I noticed that when I switch to sport + the “shock led” does not illuminate any more. Are others finding the same issue when switching to Sport + ?
desmotesta (09-08-2021)
#552
Correct, no sport plus turning on the firm setting on the shocks. Even in individual mode. You have to manually select with the dsc. Also no flashing shock button to indicate you are in launch mode.
#553
#554
Anyone care to provide a “V3 for dummies” synopsis of what it does and how? Interested but, can’t wrap my head around exactly what it does and if it is worth the $$. Thanks.
#555
you are absolutely right, you put it in words better than I did - I put that ( feeling like one can lean in corners) down towards a surprisingly better feel and feedback from front end over stock, must say I wasn't expecting my novice self to be able to feel the improvement in "feel".
Also, one thing I forgot to mention is that the suspension finally feels "Active". As in for the first time there is a difference between how suspension feel in a straight line Vs cornering. In Stock form (with S-PASM), it just similar in corners as it did in a straight line.
My "G meter" reads 1.31 after a 10 mile test drive which is the highest it has ever read (take the gimmicky sensor with a grain of salt ) Last lateral G figure was a 1.24 which was recorded after I switched from Zero to MP4S tires.
