I had the DSC Sport controller for my GT4 and quite frankly it's the only thing that helped me enjoy the car for as long as I had it. Now I've moved on to a 911 50th. I doubt it makes as much of a difference as it did for my teeth jarring GT4, but if it makes daily driving feel more compliant then I'm all for it. So the stock unit is set up for any 991.1, including those with PDCC?
Glad you liked the DSC Sport controller on your GT4. You can use the same DSC Sport controller from your 981 GT4 on your 991.1 50th. I think you'll like the DSC GT3 Tour calibration file on your 991.1.
PCA National Instructor
TPC Racing stats:
2023 Porsche Sprint Challenge 992 Cup Am Champion
2023 Porsche Sprint Challenge GT4 Pro-Am Team Champion
2022 Porsche Sprint Challenge 992 Cup & 991 Cup Champion
2020 IMSA GT3 Cup Challenge 2nd Championship
2018 IMSA GT3 Cup Challenge 2nd Championship
2016 IMSA GT3 Cup Challenge Champion
2013 IMSA GT3 Cup Challenge Champion
2006 Rolex-24 @ Daytona GT Champion
2004 Grand-Am SGS Class Champion
unfortunately I sold it. Initially didn’t think I needed it. Still don’t think it’s as essential but will probably go for it once again. Any repeat customer discounts? 100% disabled vet? Senior citizen? I can keep going!
B16 has stiffer springs then OEM so the static roll resistance is increased. And often B16 is set at lower ride height than OEM. With these factors in consideration the DSC Sport "GT3 Tour" calibration file works great with for B16. Nice ride in Normal mode over bumps. Excellent performance in Sport mode.
I too will have the B16's with a small amount of lowering (20mm has been suggested).
Would you have recommend alignment specs?
TY!
I see 4th from the Bottom is a new Tractive file. I haven't even looked at my DSC since the original setup almost 2 years ago. Dejan did a custom file for me, as there wasn't anything around back then.
Has there been any improvements since then? Should I up date to that one, or is there no need?
Dejan really knows what he's doing, so if he made a custom file to your car and you are happy with the way the car performs then I would stay with it.
if I order a new controller, can you load the GT3 tour calibration file for me? No one in the household has any windows operating systems. I don’t remember there being a way to make such a request when ordering.
We should have a reddit-style vote up/down uploads of our DSC calibration files for spring rates, sway bar stiffness/PDCC settings, tires, tire pressure, so people can give feedback on the calibrations that work best for them.
I have a bunch of calibrations I've been working on, trying to improve around town handling, and will at some point start a new thread about this. As Tom often says, it's hard to satisfy everyone because around-town handling is such a personal preference. On the track, I found the 991 Sport Tractive map works best. The Normal Tractive map causes way too much front-forward bounce on my setup (390/670 lb-in springs, GT3-style sway bars, 32/39psi cold), so I am using my own map for SF roads.
If you're interested in tweaking your maps, you don't need a windows computer - I use a Mac with Windows running in Parallels (you could also use VMware Fusion).
Tosha,
Great idea. I’ve only had the DSC unit installed for two weeks and I’m interested in getting the best settings I can. Started changing a few things in comfort mode of the 991|981 standard file. My objective right now is to get the best day to day comfort and performance. The standard 991 comfort settings have already made a big difference in around town driving.
Hopefully I’m loading and trying the GT3 touring file this weekend.
Bought a new battery for my MacBook Pro. So I can bring the laptop with me on my next day trip. I’ve got windows 10 running in VMWare VirtualBox.
Hey Tom what calibration should I use for a 987.2 Boxster S with B16 Damptronics and with stiffer front springs?
The standard DSC file for 987 works very well with B16.
If you are using stiffer sway bars such as the TPC Racing sway bars then use the DSC file for 997.1 GT3/RS. It may sound wrong but its not. All the DSC calibration files command the dampers to 100% during peak load, the difference is the shape of the curve to approach the peak.
