Just enabled Android Auto with simsaservis - SUPER easy and super quick. Highly recommended if you don't want to spend hours troubleshooting if something goes wrong.
Hi @simaservis1108 came across your work here in this thread.
I have a Panamera 2017 with PCM 4.1
2 questions..
1) Is it possible to enable Android Auto like on the 991 as CarPlay is already supported?
2) CarPlay in PCM 4.1 is not currently full-screen like in PCM 6.0... I have seen a solution with PCM 5.0 where someone coded in full screen support, you think this could also be possible for PCM 4.1?
Feel free to DM me so we can keep the rest of convo following here 991 Related!
I have an 18 Panamera and want full screen AA as well. I had it enabled on this car and its NOT full screen and I find it an annoying 20% functionality. Not really worth bothering until the screen size/resolution issue is resolved. On my 17 991 it works perfectly on the smaller screen and totally worth it on that car.
Sima hooked up my CarPlay today for my wife’s 718 Gts that wasn’t optioned with it. She didn’t have the usb in the armrest that the factory CarPlay would run off of. He activated CarPlay to work off the usb in the glove box. Then I run the wireless CarPlay adapter off that so everything is wireless and seamless. Thanks so much! Took about 20 minutes if that.. just needed a laptop, 16gb microsd card, usb to Ethernet adapter and the cat5 cable to connect the laptop to the car
2 questions..
Kind Regards
PCM4.1 won't support full-screen which is 100% sure
getting confused, are you saying that you got AA on PCM3.1 through Sim with only software coding and no new hardware?
AA on PCM3.1 and PCM3.0 no luck. Only by aftermarket CP AA box.
AA on PCM4.0, PCM4.1, and PCM5 possible via USB Lan adapter remotely. Android auto OEM way solution working
@simaservis1108 are you able to contact me regarding this? I don't seem to be able to message you directly. How can I contact you about this upgrade to my PCM to support Android Auto?
FYI, I've never used this forum before. Perhaps there is a better way to DM you?
I believe you need at least 3 posts and a confirmed account (do the auth that comes to your email) in order to PM people on the forum. It's to deter spammers and bots.
