Porsche PCM Upgrade/Hack for Android Auto? Is this real?
#361
Cheers!
#363
he can probably reprogram the dongle for you if you stick it into the pc first. then put it into the usb in the car. he can check it / reprogram it if necessary. it has to be 2.0
#364
I have the Quadlock pins now, just building the harness when that is done I am ready.
#365
#366
#367
No worries, I have it now and can try when I get a chance...
#369
Had mine done this afternoon. Thanks @Seth K ! Everything went smooth. @simaservis1108 was awesome to deal with! Wish there was something like this for my 997.2 ![Wink](https://rennlist.com/forums/images/smilies/wink.gif)
#371
Is there room in the middle under the center speaker grill, anyone look?
#372
Why do you want a secondary antenna? Granted, Waze winds up using the phone's GPS because their software developers couldn't be bothered to use the correct APIs, but I find that the phone - at least in my car (it's a Pixel 3 XL) - still gets perfectly adequate GPS coverage, and it doesn't seem to be a problem. So why install a nasty-looking wart when you don't need to? And if you really need to use the car's GPS antenna, google maps uses it.
#373
Also regarding the bolded, AFAIK Google maps would not be using the cars GPS antenna, it would use the GPS antenna in the phone.
#374
My situation may be unique, or at a minimum not usual... The GPS antenna I am referring to is not for the phone or the factory installed PCM, it is for a standalone installation of Android, heck it doesn't even use the North American satellites but rather GLONAS! ![Big Grin](https://rennlist.com/forums/images/smilies/biggrin.gif)
Also regarding the bolded, AFAIK Google maps would not be using the cars GPS antenna, it would use the GPS antenna in the phone.![Wink](https://rennlist.com/forums/images/smilies/wink.gif)
#375
