Has anyone done a CarPlay retrofit / Headunit replacement for 991.1
#1126
Click on the plus, it's a configuration process. After you click on the plus another plus will come up on a different corner, click on it too. After a few rounds of doing that you should be good to go.
For reference check this out (minute 16): https://youtu.be/4jv6AkDFqiU?t=960
got it! Thank you very much.
Got it setup and everything looks great but I get no audio! Oh man, everything installed perfect but it’s these last little bits.
did a bit of searching and looks like since I have a Bose system I need to disconnect the fiber cable from the original harness and plug it into the new Joyeauto harness. I’ll do that when I get back to it tomorrow.
#1127
About to comment to your post, yes you missed to connect the orange (I think) fiber cable. I have never made this install before because I was too scared to mess around with things, even though I have it memorized to the step. )
ahhhhh!!!!!
#1128
ha! Don’t let it scare you, it’s fairly easy really except for the quirks which you seem to already know. Appreciate the help!
c615586 (04-19-2021)
#1129
theracer21 (04-19-2021)
#1130
Just a heads up to others. My fiber connection wires weren’t orange, they were green. It makes a TON more sense when you realize it’s two wires on the far right side of the 48 pin main harness. They pop out together and go right into the harness from the unit to the back of the head unit.
#1131
Another tip, don’t do this “upgrade” if you don’t have hours to research how to install or how to make it work or sound settings etc. the instructions are sh*t
Now I can’t figure out how to have it default to switching to CarPlay when I get into the car and go. It doesn’t do anything or it goes to the aux Bluetooth and uses that instead of the CarPlay. I’m sure if I researched for an hour I could figure it out......
#1132
and in another video that I can't currently find it linked to this bit of useful info:
4. If you are using Wireless Carplay, deactivate the PCM AUX BT. This one took me weeks to figure out. Every time I would turn my car on, I intermittently had connections issues that would prevent Apple Carplay to activate or play any sound, and it would require me 4 to 5 minutes (sometimes unpairing and pairing the whole thing again) for it to work. I came to the realization that AUX BT and the Carplay module bluetooth were fighting for which could connect first. If the Carplay module connected first, no issues. If the PCM AUX BT connected first, it created a significant connection issue. Apparently the AUX BT and the AUX share the same channel, and you can use one or the other. To deactivate AUX BT in PCM 3.1 see,
. This video shows how to activate AUX BT, but you can follow steps to deactivate.
#1133
Another thing I noticed with the NM Auto/Unichip install, is that FM radio reception is hampered. The manual warns about it but blows it off as not a big deal. When driving around briefly today, local radio stations were full of static and I couldn't receive an HD radio signal any more. I don't listen to the radio that much, but it's something to take note of.
#1134
https://docs.google.com/document/d/1...it?usp=sharing
Reposting my install how to that I cobbled together from a couple of sources on YouTube and my own experience. The AutoAmateur video is excellent.
The following 2 users liked this post by c615586:
JuanK20 (04-20-2021),
poorshoeless (06-04-2021)
#1135
#1137
uphoto (04-20-2021)
#1138
#1140
Got the aux bluetooth unchecked and now it hooks up BUT only if I select Joyeauto manually in my Bluetooth settings, if I don't it won't connect at all no matter how long I wait. I'm going to try and read thru this whole thread but if anybody has any idea on what's going on there I would appreciate any help.
