New 911 Carrera T: a completely pointless marketing exercise
#196
SJW, a Carin' kinda guy
Peak Torque is the same (or near as makes no difference) base to GT3.
Think of it as a $40k off (and no ADM) GT3 with the rev limiter set lower ....
#197
Nailed it but that torque peak comes a lot earlier and another 100 lb-ft is just a tune away...
#198
The T only saves 11 lbs from the regular Carrera, mostly radio-delete, thinner rear glass and some sound insulation to give it more character. But once you opt for the Carbon seats (forces no rear seats as the buckets don't recline), that's 75-80 lbs of weight reduced, and PCCB another 42 lbs. Normally GT car weights are with the lightweight options, while all other Porsches use the standard weight (not the light spec weight).
The T may be the lightest 911 sold in U.S. since the 964, with the exception being the 997.2 GT3 RS 4.0 with all the lightweight options.
#199
Good point, the new GT3 manual saved some weight (37 lbs), but rear seats are already deleted in the GT3.
Another way to look at it is it is 500 pounds lighter than a Targa.
Edit: is that right that the PCCB saves 42 pounds over the steels?
#200
1. Is it confirmed that the 918 owners get first choice? I called my dealer immediately yesterday morning, and he knew nothing about the car. So he created a list and confirmed that I'm #1. Chances are good that I'll get one, I'd think. But with Porsche, who knows.
2. Only thing I'm not sure about aesthetically is sport tex seats. On configurator, when you spec the T interior in either red, yellow, or silver, the seats have some weave in the respective color. Can't tell if it will look nice or cheesy. And is it the same seat/weave color and pattern whether standard or leather interior?
3. If go with steel brakes, I presume they're the same brakes as the .2 base? If I recall, the .2 base gets brakes from .1 S, correct? If this is the case, they should be adequate, and preferable to Ceramics for track work due to replacement costs. Has anyone confirmed how long Ceramics are lasting when used for tracking?
#201
Ceramic and steel brakes cost about the same in the long term. Steel are incremental consumables and ceramics a large investment less often. Others can chime in about mileage but my understanding is that ceramic brakes last about 4x as long. Don't take that as gospel though.
#202
#203
You sure do talk a lot of **** for someone with a base car.... Sooooo much propaganda around what your car could be with mods. I like modding as much as anyone but lets stay focused when we discuss Porsche offerings. With enough money I can mod a 914 to race faster than you from stop light to stop light.... Comparing modded cars is a fools errand. What if I add a tune - what if I add a tune and a sticker - I'll race you NOS.... etc
#205
I think it’s awesome and I think Porsche gives each 911 variation their own reasoning and character, which goes a long way as to this cars success and dedicated and growing fanbase.
Pro’s: A collectible. Will depreciate far less than other $100K cars (as all 911’s do). Will depreciate less than other Carrera’s. Will drive better than the base. Will drive better than anything else near it’s price. Will depreciate far less than anything else at its price (there’s so much overpriced, massive depreciating garbage at $100K). All that for $104K? No brainer, imo.
Cons; Collectibility and resale won’t be as strong in the turbo gen. And “purist” doesn’t carry the same weight when it’s got two whistling turbos muffling out the sound and soul of the car. “Purist” iterations above all are about being N/A. Manual and weight matter a ton, but now more than ever (being that turbo is the new norm), N/A is the ultimate signifier.
I have no doubts that if Porsche brought back the 3.4 N/A .1 motor as a last run for this car, and gave it a 20 HP power boost (to match the new HP figure) and PSE, the price of this thing would be bid up massively, far more than whatever it will be now. And that says a lot.
#206
Porsche must be loving the BUZZ this has generated. At least 5 different threads started on Rennlist, with over 15,000 views and growing.
#207
It varies from model to model, but I remember asking about PCCB weight savings on the 987.2 Boxster Spyder and it wasn't all that impressive. Yes, PCCB meant lighter rotor material, but larger rotors and larger calipers—and, in the case of the 991.2 Carrera, much larger rotors and much larger calipers.
The more I think about the name, the more I dislike it. Too bad they didn't do "Carrera Sport" (CS for short...) or "TR" in a reference to the old T/R back-door base car race car. The badge doesn't make any sense historically (the original T was an austerity car, not a purist's car) or now (the Touring is a "tamer/less visually aggressive" car). The "T" also looks visually unbalanced, so badge delete—and stripe delete—would be the only way I'd order a Carrera T. Too bad one can't delete the embroidered "911" in the headrests, the gray mirrors, and the gray wheels.
As for the car? Besides GTS pricing proximity once desirable options are added, this is one of the most desirable 911 model offerings to come along in a long time. It represents a break with 20+ years of model strategy, and a welcome one.
#208
Originally Posted by LexVan
Porsche must be loving the BUZZ this as generated. At least 5 different threads started on Rennlist, with over 15,000 views and growing.
#209
But you'll likely never have to replace the PCCBs, while you'll run through plenty of the iron pads and likely rotors.
#210
