RS style Carbon side vent inlet scoop group buy
#286
#287
#289
Carbolution can we kindly have an update please? For 4-5 months of the year SWMBO uses her car regularly at 200mph at weekends. Quality issues aside as soon as I heard the use of glue or tape I'm nervous. Are they going to stay on the car when she's doing 205mph? VMAX the car regularly and potentially embarrassing/dangerous bits flying off the car.
https://www.carscoops.com/2020/06/ca...p-nissan-gt-r/
TurboS_GG (07-23-2020)
#292
TurboS_GG (07-24-2020)
#297
We strongly suggest getting them to install by the shop, but if there are no shops you can source nearby please make sure the surface is clean thoroughly and well with alcohol and USE adhesion promoter to enhance the bond between the surface and the tape.
The following 2 users liked this post by Carbonlution:
Agentorange (07-23-2020),
AnthonyGan (07-24-2020)
#298
One thing I noticed when I removed the OEM vent was how it has clips on two sides. But the ones from carbonlution only has clips on one side, and the other has double sided tape. Seeing this I was curious if other manufactures did the same thing. I contacted DB Carbon and they sent me a photo of theirs, which is the 2nd photo. I noticed the have all the oem clips and use the double sided tape as well. This is just something I noticed, I will be installing my vents today though hopefully fitment is well.
#299
The glue was a pain to get off, but a razor worked well so long as your hand is steady.
THE FIT IS EXCELLENT!
PLUG N PLAY!
Very well done @Carbonlution
Install tip:
1)Alcohol wipe area.
2) angle intake such that clips are close to where they snap in. (Keeping 3M tape away from body)
3) understand the 3M tape garbs quick and hard!
4) push to snap in then press where 3M tape is. DONE!
They sent me extra tape but didn’t need it. That sucker isn’t gunna move! No gaps, flush all around. Yay!
Some residual glue, you won’t need glue.
dirty car, been raining in ABQ a ton, she’s not a garage queen
PLUG N PLAY!
Install tip:
The following 3 users liked this post by Agentorange:
