Orthojoe's track build journal
#1351
Fascinating indeed. I'm tempted, except that those cambers seem way too high for road use, and I drive the car to tracks that are up to 6 hours away.
Krisa9977, could you share your impressions of the car? What you like, don't like, how it compares to other cars you've driven? I don't want to derail Joe's thread, so you can post in a new thread, or in my 'impressions' thread if you prefer: https://rennlist.com/forums/991-gt3-...nifold-15.html
You need more camber to go faster in corners and accelerating out of corners, but not for braking. If you brake hard before a corner, but go slow in a corners, your inner part of your tires will wear out unevenly very quick.
At the track you'll get much more grip with ANY tires, you'll get rid of mid corner oversteer and your rear end will be much easy to control. You can be much sooner on the throttle exiting a corner with much higher exit speed.
#1352
Received 1,259 Likes
FWIW, I had -3 degrees at the front with MPSC2 and front tires wore more on the inside, and I also got a slight bend on the inside of the wheel from a rather minor bump. I went back to -2.8, and so far fronts wear very evenly. So going beyond -3 degrees is not something I'd do on my dual-purpose car.
#1355
Hard to follow some of the extreme numbers in this thread.
I have a new RS and at the Ring the next 3 days.
Changes:
-2.5 R camber
-3.0 F camber
Zero toe front
2 mm in each side rear
Bars in the middle.
Felt fine and comfy driving on the road 20 miles yesterday in slow traffic speeds.
Car felt fine stock, MPSC in front seem to wear outside edge. Ran in the door pressures hot 29F 33R.
If anything there was some under steer but that was my driving, faster in slow corners, slower in fast corners being well within the cars limits it took a good lap of 9 minutes to get the tires up.
Made changes based on what I know from 997RS and anticipating pushing the car harder on the front tires as I get more comfortable at the Ring / going to easy safer tracks next.
I'll go out today and feel the car out for a few laps but it's a big traffic day so more caution than pushing the car....Monday and Tuesday are track days, with Manthey track support, if I really find a negative effect, I ask Manthey to make a change.
I have 2 additional sets of MPSC2 with me, so not too worried about risking killing off the tires for this trip experimenting during 20 track days 8-9 different tracks so I can learn what works best coming home with the car going forward.
Keep you posted, thoughts welcome.
Changes:
-2.5 R camber
-3.0 F camber
Zero toe front
Bars in the middle.
#1356
Hello all,
I'm new here (first post now).
I have read all of the posts here on your thread, orthojoe - some great stuff.
Lots about the MSC2 and Tropheos but not much about the Dunlop Sportmax Race.
Has anyone compared the Dunlop?
#1357
Location: Mid-Atlantic (on land, not in the middle of the ocean)
Received 4,506 Likes
The Dunlop is fine for the road, will not last on track.
#1359
I've tracked the Dunlop on a Cayman and 997. In both cars, the tire was fine on track up to about 8/10ths, but when pushed harder than that it would get very greasy, chunk, and eventually cord before the overall tread was worn down, so they provided only a fraction of the lifespan of the Sport Cup 2.
#1360
#1361
Changes:
-2.5 R camber
-3.0 F camber
Zero toe front
Bars in the middle.
Changes:
-2.5 R camber
-3.0 F camber
Zero toe front
Bars in the middle.
#1362
Yes, similar camber F/R is the way to go with 991GT3. May be even more rear camber then front. With 997GT3 it was possible to set more front camber then in the rear, but because of active rear suspension on 991GT3 it requires more negative camber in the rear then it was on 997. I would also put the rear bar in softest position.
#1363
I'm not sure how accurate the g meter is, but here is what it read after a tract day at our local (GP) race track with the Dunlop. It was actually faster than other 991 GT3's previously at the same track.
What I did learn, is the Dunlop was not happy with the lower pressures I'm used to running (and you guys are running on the MSC2). It started to tear itself up at less than 31 hot. At 36 hot is was fine and lap times were also fastest.
#1364
#1365
