More info on fancy electric tool for Centerlocks
#107
The difference in this discussion now vs earlier, is now you don't need different lug nuts, OEM works fine. Big difference compared to what was needed when this first came out. Would buy for sure at $3500, still swallowing hard at 5k.
Dufferdad (11-30-2021)
#108
Basic Sponsor
This thing is pretty sweet. Took longer to move the lights around than it did to actually R&R the wheel. Happy to answer any questions you guys have.
Ted
Ted
Ted Anthony
Sales & Marketing Manager
Ted@dundonmotorsports.com
Dundon Motorsports
+1.253.200.4454
www.dundonmotorsports.com
Ted Anthony
Dundon Motorsports
+1.253.200.4454
wiredup (11-10-2021)
#109
Did you try the Renn torq tool prior? how easy is controlling the torque upon removal, meaning as opposed to having to block the brake?
#110
- Early days, so the price listed on your website is current? The price point might be a bit high.
https://www.dundonmotorsports.com/pr...-torque-system
- Regarding the reaction arm, a little concerned about the pressure against a single spoke and the surface damage it could do to that spoke...?
- Does the version you are showing with the reaction arm do the installation in one 'set' of moves like the version that uses the HYTORC nuts?
#111
Basic Sponsor
@wiredup Have not tried the Renntorq tool. The reaction arm works both ways, so removal is incredibly easy.
@Westcoast Base price of $4995 (with no other accessories) is correct. Can't do much about the price point (we are actually offering a discount compared to Hytorc's retail price, about $350 cheaper). It's a precision tool that is *very* similar to what the factory uses to install wheels. The torque process is very slow (compared to something like an impact gun), so the pressure on the wheel spoke is minimal. The delrin "sleeve" doesn't leave any marks and seems to be very gentle. There's almost no "wrenching" of the system when peak torque is applied. The only thing I would do is encourage you to clean the wheels before torqueing to minimize scratches. The gun comes with the correct software to accomplish the whole process with one trigger pull, as it did in the first iteration. I found doing it manually to go a bit quicker.
#112
Pre-ordered from dundon. This is a no-brainer imo even at this price point if you are tracking the car enough. Even just having the utility of bringing two sets of tires to the track and being able to quickly swap them out is worth it. I'm getting too old and too lazy/weak to do the breaker bar torque routine.
#113
#114
Mostly a moot point but, are you saying that the threaded portion of the HYTORC replacement nut has a shorter threaded length then the stock Centerlock nut?
#116
![Unhappy](https://rennlist.com/forums/images/icons/icon9.gif)
CL is a complex coordinated system of parts. Any weakening will create problems. Not necessarily immediately, but miles later.
#117
HYTORC is in the business of mission critical fasteners and IIRC this was for one of the owners cars so I would be surprised the HYTORC CL nut was 'under-engineered'. Personally I think that the HYTORC replacement nut and the external castle design edge is a better way to hold the assembly during installation and removal then a reaction arm,
#119
It is my understanding from a follow up video posted by Matt that it was decided most end users would be hesitant to stray from the Porsche OEM CL nut and because of that the reaction arm process was chosen.
#120
Actually I would have thought HYTOC would have done this before showing the system to Matt, as this is their area of expertise, the accurate torque application to mission critical components.
