What did you do with your 987 today?
sasilverbullet (03-01-2024)
#1457
I see your in Austin, check out https://www.longhornpca.org/competitive-events. We run not far from you, New Braunfels. I'm there every Autox.
#1458
Began to pray that the RMS doesn't need attention after the left output seal was replaced and they saw some residue last week. Cabin air filter this weekend with some vpro nitro, and red line SL-1 additive. Looking forward to doing the engine air filter next weekend.
Last week had coils replaced after Matrix found cracking, injectors replaced, brake fluid flushed, and oil changed. 3K bill.
Cayman292 (03-02-2024)
#1459
#1460
Not joint, Spokes and SASCA are separate. Although we do have quite a few folks from there that join us regularly. Our events start at noon, and we have an awesome facility with covered parking and air conditioned bathrooms.
Aussie skypig (03-07-2024)
#1462
i was told by the PO that it'll add approx 25 hp to the equation (currently around 400) with some noise and i have to live with a CEL if it shows up, lol if the increased power is noticeable in the seat of the pants i'll keep it if not i'll put the oem headers back on the next oil change. I have an access to a Mustang dyno so it's on the bucket list. Not sure how far are you from Lumberton, NJ you can come on the dyno day and maybe dyno yours too for free if you need one. DM me if you can.
#1465
https://deadweightindustries.com.au/...ucts/touge-max
They say on the website that the next smaller/cheaper model suits the Cayman (and this model the 911).
But I contacted them, and they said for a road car, that sits around, maybe with a slight drain for security system etc, this was a better option.
My baby lives on a hoist for 2 weeks at a time while I’m at work. I usually put a charger on it when I get home. Especially with the aging led acid battery.
I bought the matching Lithium charger. It claims it “wakes up the cells”. So maybe 1/2 hr on the charger each month might still be best.
Using lithium batteries on my bikes - very little self discharge. Even if I haven’t started the bike for months, they usually crank real fast. No waking up cells required.
So, who knows?
Actually, does anyone know?
If it cranks ok, and I drive it, is that as good for the battery as putting the charger on it?
So, who knows?
#1467
Aussie skypig (03-11-2024)
#1470
With 140K miles, I started into some much needed preventative maintenance. I started having the rear axle boots leaking/ cracking so decided it was time to replace them. While I was in there, might as well do the rear wheel bearings. Pressed new ones back in this weekend. So much smoother. The old ones were getting pretty bad. Going to work on the axles this weekend. Trying to think if there is anything else while I am in there. Considering replacing the clutch as well since I already have it this far apart. It's just difficult as I am doing all this on jack stands.
