Recall #AMC0 REPROGRAMMING TCU AND ECU
#107
No, it just lowers the shift points when Sport+ is used in Auto mode.
So they say, anyway. Actually they don't even say that much -- they just say that it will improve emissions but not impact performance, reliability, or economy.
#108
I've come across one guy with a 911 4S that went thru reprogramming at a dealership. After the tune and with sports +, the car will not let you rev over 5k rpm. It'll shift automatically for you no matter which mode you're on, auto or manual.
#109
That doesn’t sound right to me. These engines don’t comes on cam before 5/5.2k rpm. If your info is correct, the guy has a problem unrelated to the recall as designed
#110
I'm not sure. The car was new to him and he asked me about sports+ function and he said that it won't let him rev above 5k rpm when he is on sports+. I told him about this recall as it's the first thing I thought of that might be related to the issue.
#111
I'll keep my 981 the way it is.
FYI. We also have the Cayenne diesel that required "tune" for emissions. No Bueno!
We love our Diesel; but, it has been neutered.
They can keep their $250
Viper pilot (04-10-2023)
#112
I should've researched and read this post but I didn't. I was wondering how your restoration went. I'm also looking for an independent Porsche mechanic. no luck so far.
Well you can declare me the first fool who had this recall performed. I went to local dealer for a “ complimentary inspection” and they decided to throw in the recall. What the reprograming does basically is remove your sport plus switch. Now there is very little difference between the two modes. Sports plus used to be a rush, now nothing. Very disappointing. Fortunately my independent Porsche mechanic will restore my original factory settings next week. Avoid this recall.
#113
Sport Plus (at least prior to the recall) was almost unusable during normal street driving, but on the track it was pretty good. If it drives better on the street, it's not such a bad thing.
The question is really how it performs on the track. Ideally, if you're pushing the car, it should rev to a high RPM, but if you're giving it easy throttle in low gears (like leaving the grid or driving in the paddock), it would be nice if it shifted earlier. On the track during maintenance throttle, it should maintain gear and not upshift too early. Under heavy acceleration, it should run up near redline like it did prior to the recall.
#114
Just wanted to report in on this to provide another first-hand knowledge account on this reprogramming recall. I had my 2014 981 CS in for the WKJ3 Tank Leakage Diagnosis Module tech service bulletin work, and while at the Dealer, had them also complete the AMC0 Re-program DME and PDK control units recall as well. Playing with the car on the way home, I didn't notice anything different to the performance of my car in Sport. In Sport Plus, however the shift points were around 4 to 5k rpm rather than redline under less than full throttle. When I mashed the pedal, shifting occurred higher in the rev range, but still before redline. Car still hauled *** under full throttle. Overall, I'm glad I did the PDK/DME reprogram as now I believe that I can drive the car on the street in Sport Plus in auto mode rather than having to shift myself. Won't have a chance to try it out on the track until fall, but predict that I'll still be glad I completed the recall....
Kevin CS (06-20-2023)
#115
#116
Before the reprogramming, it'll auto-shift, but as the poster indicated, it runs to redline. After the reprogramming, behavior under moderate acceleration shifts at a more moderate shift point, making the auto-shift more usable on the street.
chase15 (06-20-2023)
#119
Technically the SW can be downgraded to the previous version. Problem will be getting the dealer to do it as it an emission related ECU update. Ask. If no, try an indi…
#120
Most that drove in sport + on the street manually shifted anyway because it was the only choice, and so it doesnt matter if the update has been done or not for them. Nothing changes on their end and they are still in control of the shifts
For those who like to drive in full auto mode, now have additional ability to do so in sport + mode that they didn't before the update. Drive normal in full auto and you get a normal shift response. Drive aggressive in full auto and it thinks you are on the track and it starts to behave like it did before the update. You have the best of both worlds now that you didn't have before
