964 Forum 1989-1994
My 964 C2 Transformation Build Thread
Old 03-23-2020, 12:49 AM
  #1066
Spyerx
Spyerx's Avatar
Received 1,789 Likes on 1,089 Posts
Originally Posted by Jarod964
Do you have a current/up-to-date comprehensive mod list on the car? Building a '90 C2 and would love to learn from your setup (IMO it's pretty much spot-on) - I know you've listed earlier in the thread but a summary would be super helpful.
the thread is pretty current. I haven’t done much in last year just driving it. It’s in now getting a custom rear crash/bumper bar for some extra heat shielding clearance and a few little tweaks here and there.
been building a motor for my orange car.
next would be a hot 4L.
timtim (03-24-2020)
Old 03-26-2020, 07:21 PM
  #1067
spartansix
spartansix's Avatar
Originally Posted by Spyerx
I'll post some additional pictures later after I get it working :-) these are the parts needed, plus wire zip ties heat shrink 3m super 33 electrical tape and a few other bits.
Tank: 96452801902 $69
Cap: 91162807700 $38
Pump: 431955651 $12 (MES Brand)
Pump grommet: 431955465B $12
Screw: N01021513 M6 x 15 (hex head) $3
Washer: N0116667 M6.4 $1
Rubber Sleeve: 91161241300 $3.25
Hose: 99918172240 5m 4.6 x 8.2
Okay, stupid question time.
I ordered all the parts to do the RS Washer Tank Conversion, but I can't see where the pump grommet and the rubber sleeve go. Help?
Also, I assume the screw and washer are used to attach the tank to the mounting point, and guess they sent me the wrong washer as the washer doesn't fit into the mounting area?
If that's right, I can just substitute a smaller washer, I'll handle the $0.43 loss.
Old 03-27-2020, 07:59 PM
  #1068
Spyerx
Spyerx's Avatar
Iirc the pump grommet goes in bottom of tank and pump inserts into it
the rubber sleeve may be used if you run washer hose into body. Can you post pics of the 2 parts?
Old 03-28-2020, 12:35 AM
  #1069
spartansix
spartansix's Avatar
Here are the parts I got
Old 03-28-2020, 12:09 PM
  #1070
Spyerx
Spyerx's Avatar
The 4 parts are in the diagram as:
22
30
31
24
I'm going off memory as it was a few years ago. I didn't end up using 24 as i routed the hose up by the shock tower, If you want to route the hose like it was on the RS you'd drill the fender and use that grommet
I also recall the washer being odd and not fitting, i found one that worked.
#22 shows how the grommet goes to the pump and holds the pump to the canister
Old 04-30-2020, 04:04 PM
  #1071
Sirenty
Sirenty's Avatar
I saw you were talking abut gearing a couple years ago. Did you ever go forward with that or did you stick with stock? Any transmission upgrades?
Old 04-30-2020, 06:30 PM
  #1072
Spyerx
Spyerx's Avatar
You know when you have good intentions and well you just enjoy whatcha' got? I'm there with the red car right now... its at BBI getting some tweaks to the exhaust (whats on the floor is my "on road setup" )
I never settled here on a direction, will likely wait until I build the motor...
Old 05-19-2020, 06:57 PM
  #1073
Spyerx
Spyerx's Avatar
Heat management!
Old 05-22-2020, 01:57 AM
  #1074
ForeverCar
ForeverCar's Avatar
Just finished reading this. Thanks for sharing!
When is the 4.0L engine planned?
Old 05-22-2020, 02:38 AM
  #1075
Spyerx
Spyerx's Avatar
im building an engine for my 71 at the moment so after that. Later this year probably.
Old 05-22-2020, 09:54 AM
  #1076
964.4L
964.4L's Avatar
It seems like I have been living under a rock as I have just come across your thread. Super cool stuff here and love your car!
Who are you going to get to build your 4.0L?
Old 05-22-2020, 05:43 PM
  #1077
Spyerx
Spyerx's Avatar
Ha yeah, my insanity on this car started a while back. It's really the way I like it. Engine/Trans, maybe a change to an Ohlins TTX damper at some point... I just drive it, a lot.
I use BBI Autosport almost exclusively for many, many years on all my cars ( I do have a great shop that works on my 71 for some of the 'old car stuff'). They would build the engine. They are currently starting assembly on my 2.8L for my '71. You can see link to that in my signature.
Old 05-23-2020, 06:32 PM
  #1078
964.4L
964.4L's Avatar
Awesome! And BBI seems like a seriously quality outfit. Looking forward to seeing the next stage of your build.
Old 05-23-2020, 08:12 PM
  #1079
Spyerx
Spyerx's Avatar
Hit the canyons today. Up Angeles crest, Angeles forest, little tuhuanga.... ach was mobbed with pious and Tesla’s going hiking.
little t was wide open. Let her rip.
Re71r. Good. For street feel sharper on turn in than nt01. They are loud.
then again the whole car is loud. Hahhahah
but damn is it fun in the canyons. Chassis is amazing.
The following 2 users liked this post by Spyerx:
911Jetta (05-24-2020), 964Luftballoon (05-25-2020)
Old 05-23-2020, 08:17 PM
  #1080
ForeverCar
ForeverCar's Avatar
What size RE71R are you running?
Glad to hear you are enjoying the car!
Quick Reply: My 964 C2 Transformation Build Thread
