The silly little question thread ...
#166
Funny, I emptied my vacuum cleaner's capacity 2x after vacuuming. Probably a 1lb of just crud, quarters (paying dividends!), pens, a rusted allen wrench, pack of gum.
I also pulled out what I think is the OEM blaupunkt amplifier or whatever. That weighed a good 3lbs.
does your headlight level adjuster work? if not look for the vacuum line that runs along the loom there
in last pic on the right ... it might be punctured or kinked ... good time to check
otherwise just check everything is secure and not causing rattles
and vacuum every nook to get rid of that extra weight
will look great with the track ali installed!
#168
correct. 89 C4 cars have a single rotary **** for the differential lock. To activate the spoiler manually, there is a small switch in the engine bay on the deck lid beside the spoiler motor.
#172
<<<@!1!@>>>
This is the one I got, its not cheap by any means and it was tough to hit the order button, but I didn't want a cheap rubber look and have to play with silicone to prevent leaks. Its a nice looking piece. I think it ships from Greece, so it takes a little while before you get it. I really like the cleaner look, plus I never need to use mine.
#173
I have micro-cracks at the base of my magnesium fan. Until I order the new fan and get it installed (professionally as it seems there is a lot of wrenching),'to ease my disquieted mind while driving, would it make sense to put a little superglue inside the cracks and ensure I balance it with equal amounts at the opposite side?
#174
Super glue isn't going to help. But if you want to see what happens to the trunk and engine bay when the fan fails, there was a good thread not too long ago. What a mess...
#175
which MOTIV bleeder are people using ... the red label or the black label one?
seems the black is only a bit more pipe and some ali bling ... am I missing anything?
thanks!
Matt
thanks!
Matt
#176
Any good body shop paint supplier can formulate it for you on the spot.Just bring your paint number.You can get any amount.From a half pint to a gallon,or a rattlecan if you ever needed one.Ask any body shop where they get their paint.The little bottles from the dealer are a ripoff to me.
#177
I had the same questions, is it worth the extra money, etc, but there were enough horror stories to make it worth while.
With a C2, would it matter as much? Not likely, since you would be less likely to wet bleed.
#178
IHI KING!
+1 - I bought the Motiv Pressure Bleeder - Black Label which came with an aluminum cap. It works for both my C2 & C4.
#179
I found a great deal on a slightly used red label version locally. I use teflon tape on the threads of the reservoir to avoid any leakage. It's held up well in four years of light usage.
