964 Forum 1989-1994
The silly little question thread ...
Old Jan 13, 2015 | 10:22 PM
  #241
John McM's Avatar
John McM
Originally Posted by hockenheimr
When people rebuilt their engines, do they put them back in with the lower engine covers? I don't know what they are called but I guess they are for heat.
My covers were off prior to my rebuild and remain off.
Old Jan 13, 2015 | 10:40 PM
  #242
pi5tolpete's Avatar
pi5tolpete
Originally Posted by deadendd9009
Does this seem too good to be true? 200$ for both lower valve covers w/gaskets http://www.vertexauto.com/ShowItem/2...ver%20Set.aspx Anyone ordered from them before?
Seems like a very good deal. Like 50% of the price of a used set on eBay. Good find. They list a single lower cover at $94 and a single upper at $475!!!
Old Jan 13, 2015 | 11:03 PM
  #243
pi5tolpete's Avatar
pi5tolpete
Correction. The do offer the upper set for the same price. $198. Made by VTX performance.
Old Jan 14, 2015 | 06:02 PM
  #244
deadendd9009's Avatar
deadendd9009
This is what Im wondering, if these covers are any good? Or should I have my Mg covers media blasted and repainted?
Seems the Al is simply a better way to go since I won't have to deal with Mg corrosion.
Old Jan 14, 2015 | 10:05 PM
  #245
Mr.Alex's Avatar
Mr.Alex
On the topic of steering rack bushings; go oem or poly? I found some threads on here where people got poly, but no one ever really posted if it makes a difference. Threads are too old to bump again.
Old Jan 20, 2015 | 12:15 AM
  #246
pi5tolpete's Avatar
pi5tolpete
My workshop manual Volume 1 indexes a section 19 on engine cooling but I don't have that section. I go from 17 to 20. I'm looking for engine cooling oil line information.
Old Jan 20, 2015 | 08:55 AM
  #247
cobalt's Avatar
cobalt
What do you need to know? The PET can be downloaded from Porsche which will show you the different lines and general routing.
Old Jan 20, 2015 | 09:18 AM
  #248
pi5tolpete's Avatar
pi5tolpete
I have the PET, but I'm still interested to know if there is an ENGINE COOLING section 19 in the workshop manual.
Old Jan 20, 2015 | 09:53 AM
  #249
deadendd9009
Hey all,
I am trying to figure out the oil path in our cars. I want to know because when I removed my lower chain tensioner, there was a lot of crud down there. I wonder what is the lowest point of the oiling system? On the same idea, I drained 8 liters of oil when doing an oil change, even after letting the cooler get to 81 celcius. How many liters does the tank actually hold and why is it bad if its overfilled?
Thanks!
Old Jan 20, 2015 | 10:34 AM
  #250
tm.cz's Avatar
tm.cz
My copy also skips sections. Goes from 17 Engine Lubrication then the next is 20 Fuel Supply. I always assumed that they kept the missing sections in reserve when they first published is case they had to later add new pages.
Old Jan 20, 2015 | 11:04 AM
  #251
cobalt's Avatar
cobalt
Hey all,
Thanks!
Not exactly sure of your question although the lowest point in the system should be the oil pump pick up. Too much oil will flood the system and you will end up with too much oil flowing back into the cylinders and creating a mess. The PO of my C4 did this and there was oil oozing out of everywhere it could.
Off Topic
John I see you picked up a cayman R nice ride.
Old Jan 20, 2015 | 12:57 PM
  #252
John McM's Avatar
John McM
Originally Posted by cobalt
Not exactly sure of your question although the lowest point in the system should be the oil pump pick up. Too much oil will flood the system and you will end up with too much oil flowing back into the cylinders and creating a mess. The PO of my C4 did this and there was oil oozing out of everywhere it could. Off Topic John I see you picked up a cayman R nice ride.
Yes, Turbo goes to the shipper today and the R takes it's place in the garage. Can't wait to get it on the track. It seems very focused out of the box. Not doing a single mod. I am however working on an engine management kit for the C4.
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
Old Jan 20, 2015 | 05:06 PM
  #253
cobalt's Avatar
cobalt
All the best with it. A good friend of mine picked up a cayman R full track prepped a few weeks back it will be a beast of a car to compete with and I will pedaling very hard to keep up with him and expend 10 times the energy. IIRC he is pumping 370HP with full motons.
Old Jan 24, 2015 | 07:42 PM
  #254
John McM's Avatar
John McM
Thanks. First run through some twisty back roads today. Beautiful
File Type: jpg
File Type: jpg
File Type: jpg
Old Jan 24, 2015 | 10:27 PM
  #255
StopLookGo's Avatar
StopLookGo
Why does going from 3.6 to 3.8 cost so much?
