The silly little question thread ...
#152
Yay, got my passenger seat out. Anything I should do "while I'm at it"?
I have my rennline full race floorboards. Also thinking of removing the blaupunkt thing as I removed the aftermarket stereo already. Probably not going back to stock, so figure I can pull that. What are the other things I'm looking at, and anything I should do besides clean it up?
#153
does your headlight level adjuster work? if not look for the vacuum line that runs along the loom there
in last pic on the right ... it might be punctured or kinked ... good time to check
otherwise just check everything is secure and not causing rattles
and vacuum every nook to get rid of that extra weight
will look great with the track ali installed!
#156
4 bolts on the exhaust flange and then the donut clamp. Lastly is the O2 sensor that gets unplugged in the engine bay and then fished through the engine tin hole by pressing the rubber grommet out. The skid plate on the bottom needs to be removed to access the nuts and bolts. 15 minutes maybe.
#157
#158
#159
So windscreen out and perfect access to dash - anything I shd consider doing while here?
It have removed aircon ... Maybe there's more weight in dash worth removng
Or a serviceable part worth looking at?
Thanks!
Thanks!
#161
Alex I think Pelican and Suncoast may have per other thread/comments ... but I'm considering these
http://www.racingbrake.com/
964 not listed but they said they had the rights sizes
#162
Basic Sponsor
Misc. caliper parts for 964 models. Send us an email if you have any questions. We're always happy to help
964 Replacement Brake Parts
SuncoastParts.com
Your #1 Source for Genuine Porsche Parts and Accessories on the Web!
Visit us at http://www.SuncoastParts.com
Call us at: 877-923-1700
Email us at: Parts@SuncoastParts.com
Follow our Project 718 Build Thread!
Stay connected:
Join Our Newsletter
Facebook
SuncoastParts.com
Stay connected:
Join Our Newsletter
#163
For a 1990 C2, for just ONE caliper, do I need both the 40mm piston and a 36mm piston?
#164
Former Vendor
