964 Forum 1989-1994
The silly little question thread ...
Old 04-23-2023, 10:11 PM
  #2086
JohnK964
JohnK964's Avatar
Like the other posters said one plug goes to side marker light row cars have that US cars don’t the other heated washer nozzle and the other frunk light switch before that got moved to the latch
Old 04-24-2023, 09:32 AM
  #2087
cobalt
cobalt's Avatar
Received 2,052 Likes on 1,232 Posts
Originally Posted by jreifler
Well, you’re onto something @cobalt. A quick correction - The switch IS an on/off toggle. Not the spring loaded type. Also, whereas my ABS light used to come on immediately on startup and not go out, now, with the switch pressed to the “on” position, the light and warning doesn’t come on until the car starts moving.
Here’s what I found on inspection:
So, the switch is connected into that pin of the R34 relay you can see the solid blue to brown wire running to. I barely understand electricity itself, let alone automotive applications, so I am absolutely not figuring out what this means on my own.
The striped blue wire from the switch (a ground??) seems to follow down into that much larger morass of wires. But no idea where that goes. I guess maybe that originally ran to the pin in the relay where the solid blue / brown switch wire is now??
Assuming that is an ABS switch, how does this play into the warning light issue? Bonus points: What do those connectors near the hood strut go to, and why are they unplugged??
EDIT: Logic suggests that wire coming from the big bundle of wires probably comes from the ABS controller and is what *should* be plugged into that switch pin in the R34 relay. Yes?? Would that just override whatever the switch does?
Was a busy weekend.
So from what I gather someone spliced the ground wire and installed a toggle switch to defeat the ABS system. This isn't the normal way to do it but I suppose they had their reasoning. I can only assume that one way the switch kills the ABS system the other activates it but from what I am getting from your explanation is the ABS system is throwing a fault code when it isn't deactivated. I would say it is OK to leave the switch but note which is on vs off and you will need to spend some time diagnosing why the ABS system is not functioning when the bypass is not being used.
Please let us know what you find out. Also you can check the switch by using a multimeter and check for continuity. The ABS system fault showing after driving is another story.
Old 04-24-2023, 01:27 PM
  #2088
jreifler
jreifler's Avatar
Received 1,024 Likes on 486 Posts
Originally Posted by cobalt
Was a busy weekend.
Yeah. There's obviously an ABS issue independent of the switch, which is probably why the light would go off momentarily when the switch was activated on idle, but then come back on while driving.
So, I wound up just removing the switch, and reconnecting the original ABS wire to that relay. Rather not add the potential of the switch itself causing issues into the ABS troubleshooting scheme. I'm guessing now that the ABS warning only activates at speed, I may still have a wheel speed sensor issue, despite replacing the front left sensor. Will keep tracking this down and update.
Any clever guesses on that other random strand of wires and connectors I found ?
Old 04-24-2023, 04:54 PM
  #2089
jeff33702
jeff33702's Avatar
I vote to turn that switch into a "dark mode" switch, all lights off, even brake lights. aka - Escape Mode
Old 04-24-2023, 05:07 PM
  #2090
JohnK964
JohnK964's Avatar
🤣Had my Harley set up where my brake light switch was a thumb button on the handle bar
Old 04-24-2023, 09:33 PM
  #2091
jreifler
jreifler's Avatar
Lol. May add a smoke screen function as well.
While we’re on electrical connector mysteries, I have another. Prepping to install KWV3 and found this while removing rear struts. Just hanging out. Not connected to anything, and there doesn’t look to be anything to connect to . . . Anyone know ?
Old 04-25-2023, 03:29 AM
  #2092
uli1266
uli1266's Avatar
That looks like the connector for the cruise control unit
Old 04-25-2023, 10:10 AM
  #2093
jeff33702
jeff33702's Avatar
^^ yes. RSA doesn't have cruise. I have the same open connector on mine.
Old 04-25-2023, 10:53 AM
  #2094
jreifler
jreifler's Avatar
Sweet! One less thing wrong! Thanks, guys.
Old 04-27-2023, 02:47 PM
  #2095
ePa
ePa's Avatar
Does anyone know where I could get clip which is holding hallsensor bracket on distributor? Could be seen next to cable connector picture below.
Didnt follow with bracket.
https://www.rosepassion.com/en/diagr...964-993-615670
Old 05-22-2023, 07:47 PM
  #2096
JohnK964
JohnK964's Avatar
Old 05-23-2023, 06:17 PM
  #2097
jeff33702
jeff33702's Avatar
What wheels are these?
Old 05-24-2023, 09:45 AM
  #2098
cobalt
cobalt's Avatar
They look like Enkei. TS-5 or similar
Old 06-21-2023, 08:52 PM
  #2099
Matt Cooke
Matt Cooke's Avatar
Guys my mirror just popped out, what do I do? Thank you!
Old 06-22-2023, 08:44 AM
  #2100
cobalt
cobalt's Avatar
Contact cement. The metal plate behind it is the heating element. These normally have an adhesive tape on the backside when new. I found the adhesive doesn't last on replacements. Clean both sides carefully before reattaching to get a good bond otherwise it will fall off again when driving. GL
Quick Reply: The silly little question thread ...
