964 Forum 1989-1994
Bitter-Sweet Beginning
Old 04-27-2014, 01:00 PM
  #121
964Andrew
964Andrew's Avatar
Originally Posted by Lemass Automotive
Take the sunroof and runners out but you can leave the roof liner in. Just release it at the edges.
Will do, thanks!
Old 04-27-2014, 11:17 PM
  #122
964Andrew
964Andrew's Avatar
Note to self: Can NOT turn (transmission to front) diff shaft with front wheels on the ground.
Old 04-27-2014, 11:35 PM
  #123
964Andrew
964Andrew's Avatar
Need help locating (tranny to body) ground cable. Is it close to the starter motor?
I found the (starter to body) ground BTW.
Thanks!
Andrew
Old 04-29-2014, 03:14 AM
  #124
964Andrew
964Andrew's Avatar
Update...
That was a serious balancing act. Im wondering if there is a trick to use just the motorcycle jack without the help of a secondary under the transmission.
Old 04-29-2014, 09:03 PM
  #125
964Andrew
964Andrew's Avatar
OK, so to rebuild an engine I just follow what he is doing?
Old 04-30-2014, 03:55 AM
  #126
964Andrew
964Andrew's Avatar
Just finished taking off A/C system. WOW, I did not realized just how much piping is involved.
Also, EVAP - keep it or trash it?
Thanks!
Andrew
Old 04-30-2014, 02:26 PM
  #127
964Andrew
964Andrew's Avatar
Default Bitter-Sweet Beginning - Need advice
Need advice on hydraulic system bleeding. Before I ship the car for paint I wanted to do some maintenance and re-condition clutch and both locks. I will re-fit them after the car is painted.
Can I bleed the system completely dry without battery or hammer?
Please advice...
Thanks!
Andrew
Old 05-02-2014, 04:17 AM
  #128
964Andrew
964Andrew's Avatar
Today, I felt like on episode of "Dirty Jobs" while removing the oil system
BTW: Anyone knows how to bleed C4 hydraulic system completely without the use of battery or hammer? crack it open and wait what happens?
Thanks!
Andrew
Old 05-03-2014, 03:26 PM
  #129
964Andrew
964Andrew's Avatar
Today: May 3, Calgary, Canada.
Somehow, I feel better having bought the C4 instead C2. More time on the road once it's done.
Old 05-08-2014, 07:56 PM
  #130
964Andrew
964Andrew's Avatar
Steel braided oil lines and an fittings - can I just replace old lines, even the hard ones with them?
Old 05-09-2014, 09:46 AM
  #131
tfitch03
tfitch03's Avatar
Holy Snow!! Is it normally that cold up there this time of year or is it another visit from the (dramatic music)...POLAR VORTEX!?!
Old 05-09-2014, 11:58 AM
  #132
964Andrew
964Andrew's Avatar
Feels like Im living behind the wall. Bunch of wildlings and white walkers too!
Old 05-10-2014, 01:15 AM
  #133
Mixter
Mixter's Avatar
It only took 22 minutes. That's what I'd do.
Old 05-28-2014, 02:43 AM
  #134
964Andrew
964Andrew's Avatar
I made a visual DIY on how to remove flag mirrors without cutting wires.
2 important things to notice:
- Use small flat screwdriver to turn the lock rings of the mirror assembly.
- Push connector pins using a special tool or with a bit of luck a small allen key.
Thanks!
Andrew
Old 05-28-2014, 10:56 AM
  #135
911Jetta
911Jetta's Avatar
I made a visual DIY on how to remove flag mirrors without cutting wires...
Very nice.
Quick Reply: Bitter-Sweet Beginning
