964 Forum 1989-1994
Motec upgrade
Old 10-12-2006 | 04:28 PM
  #121
N51's Avatar
N51
Colin,
Thanks for your reply, but all the prior discussion concerned the 964? When you have found ~340hp with Motec+injectors+intake for x$$$, then the 9M heads at ~$11000 dollars(and 10-15hp) will be very expensive hp. I'm a little confused concerning your comment on the VR, as the my focus was on your intake for the 964. The VR can be adapted, however, your intake - as you have put forth - may be a better option and simpler?
Noah
Old 10-12-2006 | 04:48 PM
  #122
Jean's Avatar
Jean
Originally Posted by SimonExtreme
I hope that Colin won't mind but let me put some real figures on the page.....
My car run on Motronics as far as we can push it on standard injectors 309bhp
Car with standard AFM and a live remap of Motronics 301bhp
Car with Motec mapped by 9M, 9M intake and decat 339bhp
(figures extrapolated based on blow up of graph and copy of own graph)
Nice thread, somehow I missed it.
Simon, care to explain to me why would a Motronic not reach the Motec level of HP? If you have already explained it, forgive me, I have just read a couple of posts so far when I stomped into this.
Old 10-12-2006 | 04:54 PM
  #123
Jean's Avatar
Jean
Originally Posted by NineMeister
Loren, I agree with you, Porsche/Bosch were never asleep at the wheel, the Motronic ecu is a fantastic piece of kit and is probably is far more capable piece of kit compared to the Motec M48 ecu that I use, but the bottom line is that neither you, Geoff, Geoffrey nor myself can easily retune it live on a dyno and have full control over all the tables within that ecu. And that is the problem, which is the only reason why I chose to focus my development around the Motec ecu.
Oh now I have my answer, so it is not really Motronic, is the tuners not knowing how to tune it. Makes more sense.
Old 10-12-2006 | 05:18 PM
  #124
SimonExtreme's Avatar
SimonExtreme
In fact, I think that the real story is that if the right person was prepared to invest the money and time, it might be possible to continue to use the Motronics for higher power engines, but it really isn't economical when there are easier options available.
Old 10-12-2006 | 05:28 PM
  #125
Jean's Avatar
Jean
Motronic is very economical, certainly less than Motec I thought.?
Old 10-12-2006 | 05:29 PM
  #126
NineMeister's Avatar
NineMeister
Originally Posted by N51
Colin,
Noah
The 9m intake discussed is part of the 9m Motec conversion and its purpose is to replace the stock airflow meter & airbox with a more efficient unit that increases the air velocity through the stock throttle body to increase manifold pressure at full load. You cannot use this part with Motronic as there is no provision for an air flow device - Motec uses a combination of throttle position and MAP/BAP for the fuel/ignition tables. Sorry if you got the wrong idea!
With respect to tthe heads, do you remember me saying that n/a tuning is a matter of fixing bottlenecks? IMO the standard head is the next bottleneck in the system. The good news is that the production 9m billet head is exactly the same as the one I use on our 3.8/4.0 litre race engines which make between 420 and 450bhp, they are a bolt on solution and require no specialist work to fit. Sure, they costs a lot to buy, but they also cost a furtune to design & develop and a fair chunk to make.There is no hard sell with a product like these, you either want them for your engine or not, and if you want them that's the price because we simply cannot sell them for less because they are barely contributing to the development costs as it is.
If you want big n/a power the stock heads fall short, so you would either need to do a lot of port welding & flow bench rework (good luck finding the right shop to do it) if you are to come close to their performance. Serious port work of this nature would typically cost around 50% of the price of a new billet head, so when you add into the equation head castings that are over 15 years old & broken ceramic exhaust port liners the price should look a little more reasonable. Of course you could always buy new Porsche heads and work on these instead, but at the last count these cost more than the 9m billet heads.
Old 10-12-2006 | 05:40 PM
  #127
NineMeister
I wondered how long it would take.....
No, with all due respect Jean I naturally have to disagree with you, the concensus is that its the tuners who do know how to tune it cannot be bothered to invest the time an money into developing it as a commercial venture that is the answer. As I said before if or when they do I will be the first one in the queue, until then I'll stick to what I know, i.e. designing engine parts that work.
Old 10-12-2006 | 05:41 PM
  #128
Jean's Avatar
Jean
Colin, I think this is exactly what I have in my car with Motronic. A MAP + throttle position combo, I have a N/A ECU, they cost $1500 to program the first time (for free most of the times later). My car is a turbo, but that only adds to the complexity.
Care to share how many of these bolt on engines have you built? So they are yielding 450BHP now??? Are these running in some race team, or under you own banner?
Old 10-12-2006 | 05:48 PM
  #129
Jean's Avatar
Jean
Yes sorry it took a bit longer this time Sorry Geoffrey and you are not happy to see me.... Sorry if I interfere with this nice "balade a deux"
I was talking about Motronic, not engine parts. As you know my car runs on Motronic, I agree it is a turbo engine, but as you "very" well know, those are very tricky to make them run on Motronic in highly tuned states...... As I mentioned above, it is $1500 to have a state of the art ECU that runs with whatever setup you want. Concerning time, it takes my tuner less than 2 days to send me back different programs, they are usually for free too
Old 10-12-2006 | 05:49 PM
  #130
Geoffrey's Avatar
Geoffrey
Jean, you have the ability to program changes on your laptop and burn a new chip which is then installed in your ECU. This is far from the capability for real time mapping with easy to use software which is essential in determining proper ignition timing. What we are talking about, you do not have.
Old 10-12-2006 | 05:53 PM
  #131
N51's Avatar
N51
The discussion, thus far, has only surrounded the street engines and it is where my thoughts are. You mention the 9M intake as now being a part of the 9M Motec conversion. With your comment in regard to bigger injectors, do you have plans to market them in conjunction with your intake+Motec? It would a viable upgrade considering it approaches ~340bhp, and would make an interesting conversion for Geoffrey's forthcoming project. As for the heads, I would think any number of fine North American tuners could - with cams - find the extra 10-15hp, and at a considerable cost savings.
Noah
Old 10-12-2006 | 05:57 PM
  #132
Jean's Avatar
Jean
Geoffrey
I am not talking about what "I" can do, since obviously it is not at the reach of every one (although it is so simple when the tuner is committed to help you). My post pointed out initially at the comment that Motronic could not be tuned to achieve high HP levels, which was later clarified by Colin in his post that I quoted...
I have MAP and throttle position sensing on my ECUs on Motronic, so it obviously is feasible one way or the other... Who needs Motec? Unless you want to......
Old 10-12-2006 | 06:06 PM
  #133
SimonExtreme
Geoffrey
Jean
Please tell me how I can get my Motronics DME mapped for MAP and bigger injectors. I also need the map to take into account the exhaust and inlet systems on my car. Please tell me how much I will need to spend. I have been looking for about 20 months for somebody who could do that. I have the money. I have the desire. The only way I can achieve what I want seems to be fitting a fully mappable ECU, such as Motec.
This is a serious question, no tricks. Show me it can be done and I will do it, so long as it gives as good or nearly as good results as is being offered by Motec tuners (not just Colin) and gives a worthwhile saving.
Old 10-12-2006 | 06:09 PM
  #134
Red rooster's Avatar
Red rooster
Geoffrey,
---Jean, you have the ability to program changes on your laptop and burn a new chip which is then installed in your ECU. This is far from the capability for real time mapping with easy to use software which is essential in determining proper ignition timing. What we are talking about, you do not have.---
but I do !!!
All the best
Geoff
Old 10-12-2006 | 06:20 PM
  #135
Jean's Avatar
Jean
Originally Posted by Geoffrey
"I am not talking about what "I" can do"
That is a good thing, because as far as I can tell, you have never been on a dyno nor tuned an engine beyond what a tuner can help you with and are committed to arguing about things you know very little about with those that do. I do not know what makes you feel that you have an axe to grind here on Rennlist, but the consistency of your threads certainly lead one to believe that you've been mistreated as some point in life.
Geoffrey, now you are getting personal...and you just made a very stupid and lowlife comment about my life of which you don't know anything about . I will be more than happy to let you know more about it in person if you wish.
I regret the minute I paid for your membership without you knowing.
The only axe that I have to grind here on Rennlist is against charlatans like you who have never built an engine in their lives and have tuned a few Porsche cars here and there and have the arrogance of making fun of real builders with more experience than your age.
I am not trying to sell anything to anyone, I am not a self proclaimed tuner, nor claim to be one. I would rather never be on a dyno than being on your dynos, based on the numbers that you consistently throw around that don't make any sense other than for a few uninformed people around here. I live in freaking Saudi Arabia and could not care less about what you do or don't , or how deep in bed you are with Colin... Fact is both of you guys have a vested interest in this and are clearly helping each other out...
Who are you to tell me what I can or not argue on this forum. With my comments I might be helping out other rennlisters from putting their money behind a Motec just because you sell it..
Simon, when you will be genuinely interested send me a PM, my tuner is not a sponsor, and I don't like to drive business for him over here (nor anywhere else that is). You want proof, look at the numbers on my signature...
Edit: Geoffrey why did you delete your post buddy?
Quick Reply: Motec upgrade
