964 Forum 1989-1994
Real cup car or fake?
Old 01-14-2021, 10:25 AM
  #286
Ken D
Ken D's Avatar
Take a look at Neil's bio some time, if he says changes were made to the cams or to timing then that's what happened.
Old 01-14-2021, 10:27 AM
  #287
cobalt
cobalt's Avatar
Received 2,146 Likes on 1,288 Posts
Originally Posted by Neil Harvey
I’m often confused but on this one absolutely on point, if the original conversation was about the first 964 NA Cup program. I was working in the Andial race engine shop at the time. I personally did all of the engine dyno testing on every cup engine. We had to make sure all engines were equal.
All the engines were removed from the cars and either had the cam timing changed or cams replaced. This part I cannot remember, which. I can remember the engines had this change done. I am pretty sure I still have all the performance numbers for each engine in a file packed away somewhere.
Steve Becker who now works with me did all of the engine work, Rich Creedon and Eric Bloss did all of the engine in and outs along with the rest of the build work.
Eric still works for PMNA and probably has more info and a better memory.
Good to know. Maybe you can get together with Bob and help him update his article. So do you recall if only the 4 parts cars had the engines sealed? These are the latest topic and cars that very little info actually exists. It would be nice to have a definitive source of information.
One thing I have been trying to figure out was the rear axle differences. Supposedly the RS had a roll pin inserted into the end of the hub would you have any info on that? Also the 20 Turbo S2 motors are another enigma that has been the topic of discussion lately. Those definitely had the cams swapped. Any light you can shed on that would be helpful.
Old 01-14-2021, 10:54 AM
  #288
pu911rsr
pu911rsr's Avatar
there were 29 cars that had their engines sealed the 25 converted cars plus the 4 parts cars. Neil thanks for posting, PM incoming
9SIX4-C4 (01-14-2021)
Old 01-14-2021, 04:32 PM
  #289
Neil Harvey
Neil Harvey's Avatar
278- 279 seems to ring a bell. I will try to find the file with all of the numbers.
Old 01-14-2021, 04:38 PM
  #290
Neil Harvey
Once the 964 Cup series was cancelled, Rich Creedon and I left Andial as soon as the last engines were dyno'ed. I then started Performance Developments. The best people to find this info would be Springer and or Eric Bloss.
As for rear axle answers, I have no clue about these. My knowledge stops at the rear main seal/flywheel of any engine.
nh
Old 01-14-2021, 05:52 PM
  #291
evo1313
2nd Gear
evo1313's Avatar
Originally Posted by 2swoosh
Need some opinion from the the experts: what's a good option regarding seats? I have a 92 OEM 964 seats coming but the issue is locating a seatbelt system for it as PO tossed it away. I am thinking purchasing Recaro Pole Position with a 4 or 5 point harness system?
How about the factory Cup race seats???
Factory 964 Cup car seats
The following 2 users liked this post by evo1313:
kecho (02-26-2021), Matt Andrews (01-14-2021)
Old 01-14-2021, 06:29 PM
  #292
Matt Andrews
Matt Andrews's Avatar
I saw you post about these in the current BaT thread. Were these ever installed in anything? Are they the same dimensions as the RS seat? mine are the most comfortable bucket I've owned. People often think they are just a pole position, but they aren't.
Old 01-14-2021, 06:48 PM
  #293
evo1313
2nd Gear
evo1313's Avatar
My father and I owned a cup car a while ago. The car came with 2 sets of seats.
I am not familiar with the RS seats to know if they are the same sizes.
Old 01-15-2021, 02:02 AM
  #294
Sword_of_the_Spirit
Sword_of_the_Spirit's Avatar
Sacrilege to put those puppies on a air hockey set! Wish I had space in the garage for one....
Those seem to have a wider shoulder than the Pole Positions. Hence a more comfortable fit.
Old 01-15-2021, 03:45 AM
  #295
stutt911
stutt911's Avatar
Talk about a great find, these things never happen to me.
Old 01-15-2021, 09:40 AM
  #296
cobalt
cobalt's Avatar
nh
Thanks for the info. Bob states only 4 were sealed. It would be nice to have more updated info. I guess when they finish the registry they hopefully will update some of the stats on these. So much has been unknown up until recently.
BTW I did find out about the axles. They do have a roll pin inserted into the end.
Old 02-03-2021, 07:39 PM
  #297
Neil Harvey
Today I had the chance to unpack some old files. Found this.
The following 5 users liked this post by Neil Harvey:
cobalt (02-04-2021), johnneurauter (02-04-2021), Ken D (02-03-2021), tjb616 (02-04-2021), zOf964Cup (02-04-2021)
Old 02-03-2021, 07:42 PM
  #298
Neil Harvey
We changed either the cams or the timing, I cannot remember. Somewhere, I should have the dyno numbers post engine work. Its going back many years and the files are buried in boxes, somewhere here. Maybe what i have posted is enough.
nh
Old 02-03-2021, 10:06 PM
  #299
2swoosh
2swoosh's Avatar
Thanks Neil but can you decipher it to us? can I guess 269 hp at 6100 rpm?
You retired now or still involved with motorsports? thanks
Old 02-03-2021, 10:53 PM
  #300
Peteinjp
Peteinjp's Avatar
This is his business:
http://performancedevelopments.com/
Quick Reply: Real cup car or fake?
