Project 2010...
#61
Some new parts.
Wössner alusil 3.0l 16v turbo pistons with Swaintech coating on the crown
![](http://www.revline.se/cars/RRXXX/2010/newpistons.jpg)
Stock 968 piston and Wössner
![](http://www.revline.se/cars/RRXXX/2010/968pistons.jpg)
Pauter rods
![](http://www.revline.se/cars/RRXXX/2010/newrods.jpg)
76 mm throttle body
![](http://www.revline.se/cars/RRXXX/2010/newthrottle.jpg)
Design 1 Racing 968 strut brace
![](http://www.revline.se/cars/RRXXX/2010/strutbrace.jpg)
Delrin bushings for the steering rack
Pauter rods
76 mm throttle body
![](http://www.revline.se/cars/RRXXX/2010/steeringbushings.jpg)
#65
Very nice Duke,
One question though... considering the amount of boost that can be safely ran with E85 do you feel that it is necessary??
Don't get me wrong, I love the parts that have been chosen, and I'm sure it will make more power overall. However it seems to me that when ran at ~ 25-27 psi, these stockish 2.5's really make plenty of power. Especially for the street.
Is it the need to tinker and create the best, or do you feel shorted with current 2.5 at higher boost?
I ask in all sincerity, and do really appreciate your selection and build.
#66
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Very nice Duke,
#67
Just curious about his thoughts regarding each setup, since he is already running E85 and higher pressure regularly.
#68
Formula One Spin Doctor
If I had a good source of E85 and PCA would allow it the track car motor would be over 11:1 ..... Possibly way over 11:1!
There are some very interesting games you can play with Ethenol. For instance you can add lots of water to it and retune the mixture. Adjust the mixture injection to reflect the correct Ethonol to air ratio ( compensating for the added water) and you have built in water injection. In theory you could run diesel like compression ratios!
Alright, it's time for some more green stuff ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
FueLab Prodigy 41402 fuel pump + fuel filter.
IMHO the best fuel pump on the market. The size about a 044, pretty lightweight, variable speed control, brushless motor, low noise, massive flow (rated at 1300 hp N/A).. High price though.
![](http://www.revline.se/cars/RRXXX/2010/fuelab.jpg)
#69
LOL, same here in Chicago
Good question,
I think it will beneficial for all of us to see the differences in spool from a 2.5, 2.8 to 3.0
Dave will be running a 2.5 gt3582r
I will be running a 2.8 gt3582r
Gustaf will be running a 3.0 gt3582r
I am interested in doing a comparison of spool/power characteristics.
Very nice Duke,
#70
Good question,
#73
Sid you may have missed one of Duke's other recent purchases. A roll cage. So this car's focus will be for the track. I suspect with the higher static c/r he will be able to run lower boost which will be kinder on the motor plus easier to drive around town...well that's just my guess anyway. I'm sure he'll be on here soon.
#74
The pump works fine up to 100 psi and delivers over 530 liters per minute at 60 psi so it's plenty enough.
#75
Very nice Duke,
The car was very fast at higher boost levels with my 2.5l but besides lacking power in the lower rpm range, I ran low boost at the track. This is a street legal car but I primarily use it drive to, on and from the track.
This new engine will have power everywhere and it will lump around with more than enough power at say 0.8 bar. But at the same time I can take it higher every now and then on the highway, no sorry the drag strip, and give me a scary face
Plus the fact that I like to have little projects and optimize stuff
