Project 2010...
It's gonna be busy winter. Here's what's on the to-do list ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Engine
A 3.0l 16v turbo engine will be built. Based on a 968 engine with variocam in place. The goal is a reliable and responsive engine. Will be running a little higher compression and use my GT3582R 0,82 a/r so the powerband should be 3500-4000 rpm long. Power? I really have no need for more than 500 bhp and that should be doable with reasonable boost.
Fuel system
* 1 044 pump isn't enough when running E85 so I might do a solution with 2x Walbro's
* Upgrade pump wiring
Suspension and mounts
Lot's to do here... But major upgrades will have to wait.
Have had oversteering problems at turn-in which have forced down my corner entry speed at the track. I run fairly soft springs, 450/650 lbs.
* New control arms in chrome moly with angled ball joints
* New springs, 650/750 lbs
* Cornerweight & new alignment
* Semi-solid engine and transmission mounts
Brakes
Have had troubles with overheated big reds. Stopping power is phenomenal with the big reds and PFC 01 front PFC 97 rear. But I was boiling the brake fluid. I will try these mods next season, hopefully it will solve my problems
* Brake ducts inplace of fog lights. 3" hose to brake disc backing plates
* A special fibre isolating material between pistons and pads
Interior / safety
* Full cage from Heigo. Poweder coated, not black not white![Wink](https://rennlist.com/forums/images/smilies/wink.gif)
* Schroth Profi III 6 point harnesses
* Will renew the seat bases to get better position
Exterior
* Install air vents in hood
* 968-mirrors in fibreglass
* Brace ducts in front
Gauges
* STACK wbo2
* ProSport 60mm peak/warning-gauges for:
- Water temp
- Oil temp
- Oil pressure
- EGT
- Fuel pressure
- Turbo pressure
That's about it!
Engine
Fuel system
Brakes
Interior / safety
Exterior
Gauges
* STACK wbo2
- Water temp
- Oil temp
- Oil pressure
- EGT
- Fuel pressure
- Turbo pressure
That's about it!
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Based on the "good things come to those that wait" theory, this will be the best head ever....
The head guy is down to worring about the last couple of CFM matching between cylinders....
Gustaf, another project besides the Hunter? Wow! What is the CR going to be with the pistons? What size exhaust, another 4 inch?
More details please....
![burnout](https://rennlist.com/forums/graemlins/burnout.gif)
Also a black 951, but the engine will be something else
Under Fredriks' ex 951 hood:
![](http://i5.photobucket.com/albums/y170/olli951/Ahvenisto2008/PICT0052.jpg)
Here's similar installation in red 951
![](http://i5.photobucket.com/albums/y170/olli951/amw951_3.jpg)
![](http://i5.photobucket.com/albums/y170/olli951/amw-kms_kit1.jpg)
![](http://i5.photobucket.com/albums/y170/olli951/amwturbo2.jpg)
The RBF600 has close to 600 F dry boiling point. But I've heard nothing but good things about Endless. A quick google showed that their RF-650 is used by Brawn F1 too. Guess I just found something better
Great to see that car is doing good! Please mail me if you have any other pics of the car in its current state. Would be great fun to see.
