Rennlist Top 10 HP/TQ
Old 08-27-2009, 08:36 AM
  #946
fast951
fast951's Avatar
Originally Posted by pete95zhn
Hey, there's space for my past engine at 2.8l+ area...!
405.7 FWhp@5185rpm, 565.5FWNm = 417 FWlb-ft @ 4837rpm, @ 1.4bar, Shell V-Power ( Euro 99 oct )
3.0l, 8-v, Holset HX40 super - #18 compressor, VRPB+MAF+MAP+WS+V-flex
Isn't Euro 99 Octane the same as USA 93-94Octane? And you were running 1.4bar boost!
John
Email
www.vitesseracing.com
Old 08-27-2009, 08:48 AM
  #947
fast951
fast951's Avatar
Originally Posted by 333pg333
1.6 bar w 98 oct pump gas + 8:8.1 c/r = a good tune!!!
Euro 98oct is similar to USA 93oct. Running 951 8V head, 8.8:1 CR and 1.6bar boost? You think this equals a good tune??
Let's see, you have fuel and ignition to tune. Let's go safe rich and say 11:1AFR (not ideal for power). With the above engine configuration and fuel octane, will need ignition timing so retarded (for knock control if possible) that EGTs will sky rocket. Not what I label as a good tune.
Obviously, something is missing from this equation. But what do I know, this is a internet HP race...
Old 08-27-2009, 12:22 PM
  #948
V2Rocket
Rainman
V2Rocket's Avatar
Originally Posted by Tom M'Guinn
He posted this in the 3L register thread/sticky:
Hello from Estonia
My 3.0 8v Turbo http://www.cmf.ee/galerii/thumbnails.php?album=1
944 s2 block with bmw pistion squirters
PO rods (from Finland) thanks to Olli
s2 cross drilled crank, balanced
s2 original pistions (cr 8,8)
2,5 turbo head with 50mm intake valves, webcam 272 cam
Kep stage 2 cluch, 996tt brakes, bilstein coilover, turbo s LSD trans, 100mm CV joins, Car PC for engine management (Vems 3.3), Garrett GT3582, 3"exhaust
dynod 421,8 RWHP 381,5 ft-lbs @ 16psi
pretty sure the 2.5 head doesnt work on the s2 block.
Old 08-27-2009, 01:24 PM
  #949
Duke
Duke's Avatar
It does, with a reshape of the front coolant port.
Old 08-27-2009, 04:32 PM
  #950
Chris White
Rennlist Small
Business Sponsor
Chris White's Avatar
ANYTHING works if you have the budget...
actually the 2.5 head on a 3.0 block is not a big deal - as long as you are getting the head worked on.
Old 08-27-2009, 05:31 PM
  #951
Olli Snellman
Olli Snellman's Avatar
2,5L heads have been modified for ages to fit S2 block. That's what Kert (CMF) also did.
Here's few pictures which tells cleary the difference
2.5L head
2.5L block
2.7L head
3.0L block
Old 08-27-2009, 05:43 PM
  #952
333pg333
333pg333's Avatar
My point exactly John. Therefore I said it had to be a good tune to hold together. Doesn't quite add up.
Old 08-27-2009, 06:41 PM
  #953
fast951
fast951's Avatar
Exactly, you know how it is. I was just clarifying
Old 08-27-2009, 07:21 PM
  #954
Rogue_Ant
Small Business Partner
Rogue_Ant's Avatar
Dyno /= endurance race.
I see no reason to say that the tune was not good. That the motor held together at the boost (~23psi) on pump fuel dictates that it was, in fact, a good tune.
Not every 951 is subjected to survive for 20min @ WOT. A short blast is significantly less hard on an engine.
The typical 951 thought process on boost is ancient. (though perhaps not unwarranted, due to the market TA)
-Rogue
Old 08-27-2009, 08:01 PM
  #955
fast951
fast951's Avatar
-Rogue
Ok, so you are saying if it lives for a dyno run, then it's good? Well, if that's the criteria, then it's a different story. To me a good tune is that the car must live and be able to handle the track environment. Even for the street, the above conditions are not a good!
What is the new thought process on boost (for the 951 on pump gas)?
Old 08-27-2009, 08:49 PM
  #956
Chris White
Rennlist Small
Business Sponsor
Turn the boost up untill the engine breaks and then back off 1 psi....
Old 08-27-2009, 09:07 PM
  #957
Rogue_Ant
Rogue_Ant's Avatar
Yes we are talking dyno, the #1spot set that precedent. Thats what this whole thread is about.
For the street why are the conditions not good?
Also what is stopping the owner from simply lowering the boost and tracking the car?
Looks to me like CMF just set that bar.
Old 08-27-2009, 09:37 PM
  #958
fast951
fast951's Avatar
No! You mean go 1 psi higher. That makes more sense
Old 08-27-2009, 09:44 PM
  #959
fast951
fast951's Avatar
Why don't you run 25psi on pump gas with 8.8 CR then you will easily figure out why it's not good! (E85 excluded!).
As for the new bar, let's see how many are going to try it and tell about it. It will be interesting to watch....
Old 08-27-2009, 09:53 PM
  #960
Rogue_Ant
Rogue_Ant's Avatar
Don't assume I haven't.
That is why its 'the bar'. If everyone could do it, it would be the norm.
Quick Reply: Rennlist Top 10 HP/TQ
