Porsche 944 Turbo restomod
Old 07-24-2021, 09:48 AM
  #346
968to986
968to986's Avatar
Beautiful! Some Cup II wheels would also look nice on your car I think. How is steering weight at slow speed with the manual rack?
Old 07-24-2021, 09:58 AM
  #347
Frank@Work
Frank@Work's Avatar
Steering at low (parking) speed is heavy, but not too heavy. Bear in mind that I’m using the sport manual rack. This rack steers heavier than the regular maual rack. I wouldn’t want to go back to the power steering rack.
Old 07-24-2021, 10:36 AM
  #348
968to986
968to986's Avatar
Yes, the sport rack seems like a great upgrade since steering ratio on these cars is a real let down. My Boxster and 914 are scalpel-like compared to my 951.
Old 07-27-2021, 12:16 PM
  #349
944M3
944M3's Avatar
I had cup imitation wheels from Italy, not sure how old. Had a real bad vibration at highway speeds. Tried the usual fixes like balancing and Racer's Edge strut mounts (old mounts were shot), but sill had the vibration. Took all the enjoyment away driving at speed. Then I lucked out and purchased a set of 17" Fikse FM5 wheels on Craigslist for a great price. Once installed, I took the car out on the highway and immediately thought something was wrong, it didn't feel the same. Literally laughed out loud when I realized the car felt smooth as glass on the highway. Haven't ever had a nice set of quality aftermarket wheels, I was surprised the difference they made. Maybe its my imagination but even the steering feels lighter and more precise. And this was on the same set of tires by the way. Planning on getting quality tires soon, which I think will make the car feel even better.
Old 09-08-2021, 05:40 AM
  #350
Frank@Work
Frank@Work's Avatar
Great news!
My current engine is a temporary engine. I have buildup the stock engine to get the Porsche on the road again and the plans were to build another engine with Darton sleeves and a 3.0 crank etc.
The plans have changed!
Through the 944online website I became aware that Porsche has the engine blocks new on stock again! It is the block with the balansshaft covers and the crankshaft girdle. BRAND SPANKING NEW!!!
I will pickup my block next wednesday at a local Porsche parts dealer.
SeaCay (09-08-2021)
Old 09-08-2021, 01:47 PM
  #351
Tom Pultz
Lifetime Member
Tom Pultz's Avatar
Originally Posted by Frank@Work
Great news!
Frank, are you getting the 3.0 S2 crankcase, 944-100-962-00 or the 2.5 crankcase 944-100-961-00 [correction: this P/N is for the 2.7 block 944-100-961-00 M44.11/12] (which is much more expensive)? I assume if the 3.0 then you'd install an S2 crank and suitable pistons, or would you build a 2.7 with stock 2.5 crank? Sounds exciting.
Old 09-08-2021, 02:54 PM
  #352
Frank@Work
Frank@Work's Avatar
Originally Posted by Tom Pultz
Frank, are you getting the 3.0 S2 crankcase, 944-100-962-00 or the 2.5 crankcase 944-100-961-00 (which is much more expensive)? I assume if the 3.0 then you'd install an S2 crank and suitable pistons, or would you build a 2.7 with stock 2.5 crank? Sounds exciting.
I'm going for the 2.5 (944-100-961-00) with a 968 crank, aftermarket rods (carrillo?) and new pistons for a 2.8 stroker.
Old 09-08-2021, 04:06 PM
  #353
Tom Pultz
Lifetime Member
Tom Pultz's Avatar
I hope you already have a 968 crank since they are NLA. That 2.5 crankcase is about $900 more than the S2 here in the US. Hope you are getting a good deal!
Old 09-08-2021, 05:31 PM
  #354
Frank@Work
Frank@Work's Avatar
I have a 968 crank.
In relation to the cost of darton sleeves including getting the sleeves in the block I think I got a great deal on the engine block.
Old 09-08-2021, 10:48 PM
  #355
Tom Pultz
Lifetime Member
Tom Pultz's Avatar
I have a 968 crank.
Good to hear. In the US the S2 block is roughly $3500 net and the 2.5 block is $4400 [correction: this is for the 2.7 block 944-100-961-00 M44.11/12]... hmmm, that's about half the cost of a 500+ HP Chevy 6.2 crate motor
Old 09-09-2021, 03:31 AM
  #356
Frank@Work
Frank@Work's Avatar
Good to hear. In the US the S2 block is roughly $3500 net and the 2.5 block is $4400... hmmm, that's about half the cost of a 500+ HP Chevy 6.2 crate motor
Ian (944online) has a better price for the 2.5 block.
Initially I wanted to do a LS3 swap, however I'm happy i went the "stock engine" way.
bobinnova (09-09-2021)
Old 09-09-2021, 03:49 PM
  #357
Tom Pultz
Lifetime Member
Tom Pultz's Avatar
I had the wrong P/N for the 2.5 block listed earlier. The correct number appears to be 944-100-960-00, which Delaware Porsche shows as "Not for Sale." I have in inquiry in to them to clarify since Sunset has it listed for $2609.97. Ian apparently has a few for $3500. This is the one you want, not the 961-00 version since that's a 2.7 block and won't work with a 2.5 turbo cylinder head.
Old 09-09-2021, 06:06 PM
  #358
Mike Goebel
Mike Goebel's Avatar
Now I'm not suggesting an LS swap but doesn't this make you think about it?
Cheap HP on Tap
Mike G.
Old 09-15-2021, 06:15 PM
  #359
Frank@Work
Frank@Work's Avatar
I was amazed at the amount of hardware included with the purchase of the new engine block! Very happy with the purchase.
Let's start with Part Deux of the restoration!
The following 7 users liked this post by Frank@Work:
Chris Moon (09-17-2021), DasSilberWedge (10-31-2021), Gage (09-15-2021), jmj951 (09-20-2021), PF (04-04-2022), Rob 3 (09-15-2021), WOLF35 (04-05-2022) and 2 others liked this post. (Show less...)
Old 09-15-2021, 09:10 PM
  #360
mj951
mj951's Avatar
Very cool, thanks for the photos!
Quick Reply: Porsche 944 Turbo restomod
