928 Forum 1978-1995
Sponsored by: 928 Specialists
Lifter noise solutions needed - (gasket improperly installed)
Old 02-27-2012, 08:14 PM
  #31
Lizard928
Lizard928's Avatar
Originally Posted by SeanR
Hmmm, guess I'll be switching.
Now to become a dealer.
Fixed it.
Old 02-27-2012, 08:19 PM
  #32
GregBBRD
Former Sponsor
GregBBRD's Avatar
Received 2,474 Likes on 1,468 Posts
Originally Posted by danglerb
I suspect this mode is unlikely as the low part of the cam defines the max expansion of the lifter vs the valve spring, no forces come to mind that would expand the lifter working against the valve spring force.
5 to 10 min most recently using MMO on a 6 month since last start, and I recall it was half and hour or more on my old Euro motor first time I started it.
How important is the oil change soon part? Swebco vs Marvel Mystery?
If the oil filter gets plugged with debris....soon.
On the bottle, it says: "When adding 502 to engines suspected or known to be "dirty", drain oil at greatly reduced intervals for the first 2 changes. Once the large deposits have been removed and drained, you should be able to safely operate your engine with longer drain periods."
"Greatly" and "should be" are a bit vague....sounds like some of "our" past 928 engine builders talking....
I think they are talking about old American V-8 engines that have 1/2" of crap in the lifter valley and the heads. I've never seen a 928 or a 944 engine anything like those things can get....although it can get pretty "thick" in the oil pan of engines that have had TBF.
Old 02-27-2012, 08:54 PM
  #33
atb
atb's Avatar
Originally Posted by GregBBRD
....although it does concern me that your lifters made more noise after a few minutes. That usually means that oil isn't getting there, properly. Cam carrier gaskets installed correctly? Head gaskets installed on the wrong side?
Didn't touch the heads, just pulled the cam boxes and inserted 4.5L cams.
Pretty sure I got the carrier gaskets correct, seem to recall it was pretty evident which way they went on. (But hey, anything's possible)
I'll try the Swepco and if it doesn't clear up, I'll order up some new gaskets and lifters.
Thanks for all info everyone.
Old 02-27-2012, 08:56 PM
  #34
atb
atb's Avatar
Originally Posted by Lizard931
I put in the ATF about 500 km before the change and try to get the oil up to as high a temp as possible.
Does that help?
Thanks Colin, how much ATF, pint, quart (milliliters ) ? Any brand in particular?
Old 02-28-2012, 05:21 PM
  #35
GregBBRD
Former Sponsor
GregBBRD's Avatar
it is fairly easy...either the oil holes line up, or they don't.
As I said, "increasing" lifter noise, after starting, isn't normal and would scare me.
Old 02-28-2012, 08:55 PM
  #36
atb
atb's Avatar
Pretty sure I got it right then. I do recall laying the gasket on both ways just to make sure I was getting it right.
Waiting for a call from "my local Swepco sales associate" to place an Order for 502. I'm being told by corporate that I need to order by the case (12 bottles) at about $9/bottle. Posted a group buy on the PacNW 928 list and am already up to 2 cases. Its going to be popular stuff up here.
Old 02-29-2012, 12:32 AM
  #37
danglerb
danglerb's Avatar
Maybe the frugal thing to do would be pour in the goop, run 500 miles or two years which ever comes first, then pull the oil filter and cut it open. If the filter looks nasty top up the oil and replace the filter and check again in another 500 miles?
Old 02-29-2012, 01:55 AM
  #38
GregBBRD
Former Sponsor
GregBBRD's Avatar
When I "light" a new engine with used lifters, I expect some of them to make noise. However, I don't expect more to get noisy, once there is oil pressure.
I'd want to "see" something positive happen, pretty quickly. If none of them recover/change, I'd want to make sure that there is actually oil getting where it needs to be.
Starting an engine up, warming it up, and then driving it 15 miles should have "fixed" some of the darn things?
Old 03-05-2012, 09:53 PM
  #39
atb
atb's Avatar
Did not get a chance to add the Swepco 502 yet. Motor died while warming up, found that the exciter wire had separated from the 14 pin plug. I'll resolder tonight and try it again.
I did make a quick video however, and I must say the sound is much different when listening to it on the video compared to standing over the motor. And I don't mean that in a good way.
Here it is, are we still talking lifter noise here, or did someone stick a diesel in when I wasn't looking?
Old 03-05-2012, 10:33 PM
  #40
Glenn M
Glenn M's Avatar
That is much harsher sounding than my 87 when it sits for a few weeks.
Something doesn't sound right.
Old 03-06-2012, 06:10 AM
  #41
S4ordie
Not the sharpest tool in the shed
S4ordie's Avatar
Ugh.... that does not sound like a lifter, but then I'm no expert. That sounds really harsh.
Old 03-06-2012, 06:39 AM
  #42
Bill Ball
Under the Lift
Bill Ball's Avatar
That's one awfully DEAD lifter. Can you localize the noise source with a heater hose "stethoscope"?
Old 03-06-2012, 09:25 AM
  #43
SeanR
SeanR's Avatar
16v lifters are larger than 32v ones so will be louder, quite possible that's all this is. Had one of our own with this issue and all it needed was to run a bit.
Old 03-06-2012, 12:03 PM
  #44
Bill Ball
Under the Lift
Bill Ball's Avatar
If Swepco 502 "fixes" that, I'll be putting it in every vehicle I own. Heck, I'll spray some on my balding head to see if it grows new hair. Worth a try.
Old 03-06-2012, 01:05 PM
  #45
Tom. M
Deleted
Tom. M's Avatar
If I recall corrrectly, Ken O had a similar sound in his track car after he swapped in that heavily ported head into the white track car.... give him a shout to see if it was a lifter or something else...
Quick Reply: Lifter noise solutions needed - (gasket improperly installed)
