928 Forum 1978-1995
Sponsored by: 928 Specialists
Engine Fire
Old Nov 9, 2011 | 05:59 PM
  #106
jorj7's Avatar
jorj7
Originally Posted by SteveG
Fred: What's a "live hose pipe"?
I would assume a live fire hose or live water hose, but you may think
something different...
Old Nov 10, 2011 | 12:45 AM
  #107
Ra928's Avatar
Ra928
Does anybody have the Mcmaster part number for the gauge? I couldn't seem to find it on their website.
Old Nov 10, 2011 | 02:00 AM
  #108
hb4's Avatar
hb4
Sorry to hear about your fire, Randy. I will be removing my Fuel Pressure gauge and capping the stub.
Last edited by hb4; Nov 10, 2011 at 03:28 PM. Reason: Removed spec for incorrect fuel pressure gauge.
Old Nov 10, 2011 | 02:51 AM
  #109
FredR's Avatar
FredR
Steve,
I have the hose in hand with the tap turned on [i.e. pressurised] and either let the hose dump water on the floor or kink my end of it to arrest flow knowing that I can have it flowing water onto the site of any fire in a fraction of a second.
If you have to use it on an engine bay fire you may well end up with water in all sorts of places you do not want it but invariably much easier to deal with than what poor Randy is having to sort out and that looks mild compared to what most engine bay fires saeem to do.
One of these days I'll purchase a hand valve/regulator thingy to stick on the hose pipe- I think I have trashed two plastic things already after blindly running over them!
Regards
Fred
Old Nov 10, 2011 | 11:51 AM
  #110
Randy V's Avatar
Randy V
25 Year Member
Originally Posted by SeanR
Randy, can you take the fuel rail cover off and post picture please? I want to know which adapter that is. It looks like there is sealing tape on it also. I'd really like to have this guage/adapter to put on my car and pressurize it up to see exactly where the leak is.
Will take additional pics soon.
Bottom line is that fuel came out of the weep hole at the top of the gauge, indicating a pass-thru failure of some type.
Old Nov 10, 2011 | 12:19 PM
  #111
Koenig-Specials 928's Avatar
Koenig-Specials 928
I've been away and just saw this. Sorry for what happened Randy but looks like your quick actions saved the day. I immediately checked mine and it looks like I have the same type of gauge with the weep hole at the same location. I am definitely removing mine and reinstalling the ball and cap as an immediate corrective action.
Old Nov 10, 2011 | 12:37 PM
  #112
DR's Avatar
DR
Rennlist Sponsor
Hi Randy,
Just got through reading up on this thread, I am so sorry this happened to your GTS. I am VERY Happy that you are OK and it appears you did a great of minimizing the damage!!
If there is anything I can do to help please don't hesitate to let me know.
All the best,
Dave
Originally Posted by hb4
I think this is it:
9780T114
Silicone-Filled Shock-Resistant Gauge, 2% Mid-Scale, 1-1/2" Dial, Center Back, 0 - 100 PSI
Guys, PLEASE PLEASE do not order these type gauges for this application from McMaster's online catalog choices. IIRC I have never found any fuel pressure rated gauge in McMaster's online system. I assume Roger has arranged some sort of special deal with McMaster and the manufacturer because the 2 similar gauges listed on McMaster.com are NOT specified as Fuel Pressure Gauges and IMHO are NOT rated for the temps seen in the engine compartment.
The gauge part number you spec'd above is stated to be used for compressed air, hydraulic oil and water ONLY...and even worse the max ambient temp rating is only 158F degrees!
The only other gauge similar to this is mcmaster part # 3850K34 and it is also for compressed air, hydraulic oil and water only..and is only rated for 140F degrees ambient temps.
As I said don't just go to a website and order something you think is similar to what is being used, at least without checking and understanding the specs.
Below are the links to the specs for the 2 part numbers mentioned, note the "For use with" specs and the "Temperature Range" ratings..PLEASE don't order these to be used as a fuel pressure gauge, especially in the heat of the engine compartment.
McMaster Part# 3850K34
http://www.mcmaster.com/#3850k34/=evhjtm
McMaster Part# 9780T114
http://www.mcmaster.com/#9780t114/=evhnxj
Where ever you get gauges for this application make sure the gauge is at least made and specified as an automotive fuel pressure gauge by the manufacturer.
Randy, my apologies for the "hijack", I didn't want to take the chance that someone here would unknowingly order an industrial General usage Pressure Gauge and use it as a FP gauge in the engine compartment.
Please Be safe!!!!!
David Roberts
2010 Jaguar XKR Coupe - 510HP Stock - Liquid Silver Metallic
928 Owners Club Co-Founder
Rennlist 928 Forum Main Sponsor
www.928gt.com
928 Specialists on Facebook - 928Specialists
Sharks in the Mountains on Facebook - 928SITM
Old Nov 10, 2011 | 01:08 PM
  #113
Cosmo Kramer's Avatar
Cosmo Kramer
When I first supercharged my car, I was smelling gas when I parked my car in the garage. On closer inspection, I found my gauge was leaking a fine mist of fuel around the threads where the gauge threads into the adapter. That mist was spraying onto my distributor cap and evaporating almost instantly. Needless to say I was very lucky I had new wires installed and nothing happened. I snugged up the gauge and it hasn't leaked since, however I think I might just remove it and only install it again if I need it for tuning. I bet I haven't looked at it for over a year now since I have had my car dialed in.
Old Nov 10, 2011 | 02:21 PM
  #114
hans14914's Avatar
hans14914
I dont want to be a threadjacker, and I really am uncomfortable recommending any under-hood fuel components for obvious reasons... however, if there is a Rev2 kit being considered, you may find the below senders to be of interest:
http://www.umainstruments.com/tso_senders.htm
They are FAA rated, so should be safe for automotive use, even in extreme conditions. Not a personal endorsement, just an "observation" for anyone interested. Use at your own risk.
Hans
Old Nov 10, 2011 | 02:47 PM
  #115
ROG100's Avatar
ROG100
Basic Sponsor
As the fuel gauge kit is meant for diagnostic purposes only none of this should be an issue. We do not recommend that the gauge we fitted to the car on a permanent basis.
Old Nov 10, 2011 | 03:04 PM
  #116
Randy V's Avatar
Randy V
25 Year Member
All the best,
Dave
Thanks, Dave. We're putting together a parts list this week.
Perhaps you need to consider updating the installation instructions that you include with the gauge indicating that.
Surely you are aware that most folks install this gauge as a permanent installation.
Old Nov 10, 2011 | 03:29 PM
  #117
Ducman82's Avatar
Ducman82
Veteran: Air Force
this is what i use. made for direct mounting.
http://autometer.com/cat_gaugedetail...gid=2813&sid=1
Old Nov 10, 2011 | 03:40 PM
  #118
ROG100's Avatar
ROG100
Basic Sponsor
Randy,
You were told by a number of very knowledgeable people to not fit the gauge permanently to your car – common sense.
I am aware a lot of owners fit the gauge to the car for testing and leave it there, myself included. That is a decision for individuals to make.
We have already warned owners about the risks after your accident. We added a note to the instructions that the gauge is meant to be used as a diagnostic tool only.
We already offered a replacement gauge kit even though there is not conclusive proof it was indeed the gauge.
We are also happy to help with discounts on parts that you may need for the rebuild.
Roger
Old Nov 10, 2011 | 03:45 PM
  #119
Randy V's Avatar
Randy V
25 Year Member
Randy,
You are out of line here, sir. At no time did you (or other 'knowledgeable people') ever tell me to not install the gauge permanently. I never indicated you had any responsibility for this incident, but if this is how you CYA I suggest you look at other ways of doing so instead of making **** up.
Old Nov 10, 2011 | 03:50 PM
  #120
Lizard928's Avatar
Lizard928
You can tell people anything you want, put whatever you want on the instructions. But getting them to listen is another story all together. If your ign leads were in good shape, this would not have happened. IMHO
An example is the amount of early cars still using alum ball joints, or cars still having the original fuel lines.
Parts do fail, nothing can prevent that regardless. We all know this from day to day life.
Yes it is not appreciated what happened, but I see no one at fault for this.
