928 Forum 1978-1995
Sponsored by: 928 Specialists
So what did you do to your 928 Today......
Old 07-29-2011 | 08:49 PM
  #1471
77tony's Avatar
77tony
Default Just Beachy
Just got "Just Beachy" back from the P&B Shop. Great to have her back home. Also was great to meet new 928 friends jeffanddeb today from Port Lavacha. jeffanddeb have a 84 S.C. 928 that we will be checking out this weekend. 77Tony
Old 07-29-2011 | 10:48 PM
  #1472
NC928S4's Avatar
NC928S4
Completed the redyeing process on rear seat cushion using Leatherique "factory" color. Started in the rear so as to learn and perfect... I'm an optimist by nature but the redye looks better than new. The seat was in "good" shape for a 23 year old but looked worn and had a few cracks. I did the recommended 400 sand paper preparation/fluid wash and applied some crack filler goo where needed. I then applied 2 coats of dye.
The pics don't show the full effect of the treatment justice. I'll be busy the next few days doing all seats because the results are amazing. More pics to follow as I work through the interior.
Old 07-29-2011 | 10:58 PM
  #1473
dimi5928's Avatar
dimi5928
Default Aero Mirrors
I just got my fresh paint (Schwarz A1) aero mirrors from body shop.
Old 07-30-2011 | 04:38 AM
  #1474
Mark in Japan's Avatar
Mark in Japan
I got my Control pressure gauge mounted.
I "hammer-tuned" to correct Control Pressure.
I started & revved my beast for the first time!!!!!!!!!!
Good Day!!!!
Old 07-30-2011 | 08:00 AM
  #1475
Maleficio's Avatar
Maleficio
I replaced all the fuel hoses for the injectors and regulators. Used the right stuff this time, 30R9, and the proper smooth clamps. Fired right up, and ran beautifully with no leaks.
Old 07-30-2011 | 08:29 AM
  #1476
Abby Normal's Avatar
Abby Normal
In Your Face, Ace
Later today I am going to reach down for the button and select High Boost
Old 07-30-2011 | 12:34 PM
  #1477
Bertrand Daoust's Avatar
Bertrand Daoust
Some caliper and disk painting.
Old 07-30-2011 | 02:19 PM
  #1478
Ad0911's Avatar
Ad0911
Default reassembled driveshafts
Reassembled both driveshafts. Much helped by the following movies:
part 1: disassembly and cleaning
part 2: assembly
Thanks to Van Svenson. The actual driveshafts are from a 914. Only minor differences, like the bevel ring between CV joint and axle stop that is not in the 928 driveshaft.
Old 07-30-2011 | 03:12 PM
  #1479
Andy Kay's Avatar
Andy Kay
Default Avoided this!
After a quick detail and a fill up. I took my 928 for a drive. This happened right in front of me this morning. Fortunately, no one was hurt.
Old 07-30-2011 | 03:22 PM
  #1480
R.Pires's Avatar
R.Pires
Unfortunately I just looked at my beautiful car parked in my garage....
My clutch is gone!
I must do a list of needed material and email Roger with my order, I decided it's better to replace all of the clutch parts, discs, plate, cylinders, etc, than fix only what broke and probably have problems again in a near future.
I dream about the day I'm going to drive it again!
Regards
Old 07-30-2011 | 06:48 PM
  #1481
NC928S4's Avatar
NC928S4
Removed and prepped Rear Interior pieces for dyeing tomorrow. Not too bad except the temperature was 103F.
Had a dangerous encounter with Murphy. The rag I was using to clean with had a thread grab a spring that keeps tension on the electric fan brushes for the rear AC blower. What are the odds? The spring popped off and went inside the electric motor. After some cussing I fetched the spring out and with needle nose pliers re-attached the spring. It was dumb luck that I got it reattached because one side of the spring was blind.
Old 07-30-2011 | 07:15 PM
  #1482
jeff spahn's Avatar
jeff spahn
I found this:
And a closer look shows:
Old 07-30-2011 | 09:59 PM
  #1483
dr bob's Avatar
dr bob
Chronic Tool Dropper
Mine look a lot like yours, except I masked the friction faces only. I added a few coats of CRC spray galvanizing to the fins so they will take a little longer to rust. I have four coats of clear over the silver on the hats, and may need to add some motre to get the same depth that's on the wheels.
Yours are looking great! Of course, we'll want to see finished pictures when all is back together.
Got some CS springs that will need painting, so I'm planning to get a quart of metallic black for them and the caliper frames. Spare time stuff for when I find some time at home.
Old 07-30-2011 | 10:18 PM
  #1484
BigAl1's Avatar
BigAl1
Rolled mine out into the sun for the first time since Sept 2010, really wanted to see the Tahoe Blue paint in the sun, and still very happy with the color!
Old 07-30-2011 | 10:22 PM
  #1485
77tony's Avatar
77tony
That sure is purrty Big Al. T
Quick Reply: So what did you do to your 928 Today......
