928 Forum 1978-1995
Sponsored by: 928 Specialists
So what did you do to your 928 Today......
Old 08-06-2017, 12:44 AM
  #7216
Bigfoot928
Bigfoot928's Avatar
I just sat in mine and made vroom vroom sounds, smelling the leather and thinking if I needed to install the fin thingy to the fan motor in anticipation to Al's HVAC controller.... mmm leather smells good...
Old 08-06-2017, 11:14 PM
  #7217
ltoolio
ltoolio's Avatar
Installed the new pod electrics solution from Roger. Lovely bit of engineering. Everything went int as expected, and all my lights are working
Old 08-07-2017, 07:48 PM
  #7218
MainePorsche
MainePorsche's Avatar
Diagnosed AC compressor failure today.
Old 08-08-2017, 10:22 AM
  #7219
axidjw
axidjw's Avatar
Default refinish the paint
Been spending a couple hours a night for the last week getting paint back from the dead..
1. 4 bars of meguires Clay bar
2. Half bottle of neguires cutting compound
3. Full bottle of meguires scratch remover polish
4. Bottle of black magic carnauba wax
5. Bottle of turtle wax ice concentrate
6. 5 buffing pads
7. About 10 microfiber towels
All swirl marks are gone, almost all scratches have been removed and burned in and it now shines something beautiful.
Total time about 16 hours
Next up is some tint next week and then sand, polish and paint the rims.
Old 08-10-2017, 04:09 PM
  #7220
Chalkboss
Chalkboss's Avatar
Replaced both door arrestors to keep my open doors from flopping closed. Old ones were toast. Can't believe what a difference such a small thing makes!
Old 08-10-2017, 06:57 PM
  #7221
dr bob
Chronic Tool Dropper
dr bob's Avatar
First steps towards swapping in the new transmission mounts -- Butt is up on stands and a casual survey of the work is done. The big question: how much cleaning will be involved? Hint: I haven't turned a wrench on it yet. Film at 11...
Old 08-10-2017, 11:39 PM
  #7222
Rhubarbbear
Rhubarbbear's Avatar
Cut up an aftermarket Audi TT spoiler to make it fit then painted it!
Old 08-11-2017, 12:31 AM
  #7223
skpyle
skpyle's Avatar
Worked on installing new Glyco rod bearings.
Old 08-14-2017, 11:52 AM
  #7224
sbirring1
sbirring1's Avatar
New exhaust system going on....getting ready for Adamants sharks in Ontario.
Old 08-14-2017, 11:34 PM
  #7225
jeff spahn
jeff spahn's Avatar
I just drove mine
Old 08-14-2017, 11:36 PM
  #7226
Adamant1971
Adamant1971's Avatar
Received 1,062 Likes on 506 Posts
Old 08-15-2017, 06:17 PM
  #7227
Chalkboss
Chalkboss's Avatar
Detailed engine for Werks in Monterey and replaced bad fuel damper. It's been bad for 2 years! It would slowly lose vacuum over 5 min. No more hard hot starts!!
Old 08-15-2017, 09:29 PM
  #7228
dr bob
dr bob's Avatar
With everything lickin' clean, I decided to try a simple hose-section "spacer" in the existing mounts, a follow-on to others' efforts and shared results. I started with a 1.75" section of 5/8" heater hose with a similar-length section of 3/8" power steering return hose stuffed inside. Squeezed together, they just fit into the gap in the transmission mounts at "full extension". The transmission now sits up where a new mount would put it.
Of course, because it's so simple, cheap, and easy, it's nowhere near the isolation afforded by new transmission mounts. I'm going to drive it a few more times to be sure, but there's definitely more transmission sounds coming up into the cabin now. The Good News is that, along with the motor mounts over the winter, there is no hot air coming up through the console with the windows down or sunroof open.
I may try just pulling the inner pieces of PS hose out of the heater hose spacers before I put the new mounts in. I know I'm going to get them in soon. Just experimenting/playing on the way to completion.
Old 08-15-2017, 11:32 PM
  #7229
AO
Supercharged
AO's Avatar
Listed (1 of) mine for sale...
Ebay: http://www.ebay.com/itm/-/142477458531?
Old 08-19-2017, 05:43 PM
  #7230
Captain_Slow
Captain_Slow's Avatar
I picked up an HF three-ton low profile jack to go with my two-ton very low profile/high lift version. Two jacks cuts the time to put the car up on LiftBars and 6-ton stands to less than half the time with one jack.
Nice to see zero metal on the plug magnet (Mobil 1 15w-50 2-year drain interval, about 5000 miles since last change, and 94,000 miles on the odo.).
Now prepping to install Greg's fuel lines (and later a new PS pressure line). Have a new battery ground strap to go in, too.
Quick Reply: So what did you do to your 928 Today......
