928 Forum 1978-1995
Sponsored by: 928 Specialists
So what did you do to your 928 Today......
Old 07-14-2016, 11:52 AM
  #6466
bureau13
bureau13's Avatar
If you do, I may have a core for you if you need it. Otherwise it's likely going in the trash.
Originally Posted by Kevin in Atlanta
The process is a secret right now. I am considering a pod and dash restoration service.
I'll probably start a new thread once I have run the numbers.
Old 07-14-2016, 11:54 AM
  #6467
bureau13
bureau13's Avatar
I removed the pod, took out the instruments and repaired the odometer gear. Also cleaned all the contacts and adjusted the fuel gauge needle. Next up, attempt to resolder the flex contacts for the speedo, adjust the voltage gauge and install LEDs, before putting it all back into a leather replacement pod.
My eyes are not doing so well with some of this close-up work lol...
Old 07-14-2016, 12:02 PM
  #6468
Kevin in Atlanta
Kevin in Atlanta's Avatar
I need cores! PM me. I'll arrange shipment. How much do you think is fair for the pod?
Old 07-17-2016, 03:59 PM
  #6469
MainePorsche
MainePorsche's Avatar
Hello fellows, it's been a while. Finally got myself, and the car, in a place where I can drive and work on it. Just put the first couple of hundred mile on after it had been in an extended winter hibernation. Started on first throw and sounds and smells great. No runs, no drips, no errors. First overdue bit a work was to repair the passenger side rear hatch switch that my son stepped on an broke off. Works like it should but ordered a now rosette and icon piece from Roger.
Old 07-17-2016, 06:19 PM
  #6470
Pappy
Pappy's Avatar
Default AACA show
Scranton region had their Antique Automobile Club of America show today. Took home first in my class. Was a little shocked as there were some nice cars there.
Old 07-17-2016, 08:10 PM
  #6471
Kiwi'79
Kiwi'79's Avatar
Haha you were shocked?!!! Have you taken a close look at your car?
That car is beautiful!!!!! Well done
Old 07-17-2016, 08:46 PM
  #6472
Bertrand Daoust
Bertrand Daoust's Avatar
Received 1,297 Likes on 493 Posts
Put back the CE panel in place after cleaning.
Started the car and everything was good for... 10sec.!
It went into limp mode - green light on the LH.
Stopped it, unplugged the LH and plugged it again.
Started the car again and everything's good. Went for a little ride and still good.
From this:
To that :
Changed all fuses and cleaned all relays.
...And back to this:
Not a big job but take some time.
Another preventive job done.
Old 07-17-2016, 09:06 PM
  #6473
The Deputy
The Deputy's Avatar
Default Received a batch of goodies Thursday...
Oil filter, steering rack boot, tools, battery ground cable and door panel cable tube trim pieces R&L for old blacky (84).
Drivers compartment black carpet, 28 - door panel black plastic attachment clips and door panel cable tube trim pieces R&L for old red (78).
Thursday:
Installed 14 new black clips on drivers door panel for the 78, snapped right in place and stayed put. I'd screwed around with the door panel for hours previously, but it kept coming loose along the top edge. Going to redo the passenger side when I get a chance. Best $28.00 I've ever spent. Replaced drivers compartment floor carpet, used, but much better than what was there.
Installed the ground cable and put new/used tools in rear compartment panel on 84.
Friday:
Took some alignment measurements on old blacky, since I'd previously adjusted ride height, and changed my torn rack boot and oil filter/oil (from hoist mishap), and made toe-in adjustments. Road test, seemed pretty good, steering wheel straight again, but will measure again after a few more miles. While putting the car back in the garage, after cooling off outside, flipped the headlights on...and they popped up...but no lights. One step forward, two steps back...lol.
Saturday:
Spent most of the morning working on the headlights, combination headlight relay seems to be the problem. Disassembled relay and cleaned all contacts, but the one solenoid that supplies power to dimmer/brights contact is not pulling down. Went through several diagnostic test and checked and rechecked wiring diagrams...will order new relay.
Sunday:
Worked on the headlights for a bit, thought I could maybe add an external relay to control power loss...but it would have been more work than it was worth. Then messed around soldering a internal jumper wire inside the combo relay. Headlights worked...but wouldn't shut off. Major brain-fart on my part once I thought about what I'd done...oh well...had a chance to improve my soldering skills.
Finished installing the last two brake wear sensor harnesses on old red. Cleaned all rims (inner portion) and installed.
Pretty productive last few days.
Brian.
Old 07-17-2016, 09:29 PM
  #6474
LT Texan
LT Texan's Avatar
Washed her and put her on eBay.
Old 07-17-2016, 10:20 PM
  #6475
supercedar
supercedar's Avatar
Drove it 1600 miles in the high dessert. Seattle to Reno NV to Bend Oregon back to Seattle.
Always paying a small price of admission to the awesome hi ways the state of California maintains for me.
Old 07-17-2016, 10:28 PM
  #6476
JParanee
JParanee's Avatar
Washed and quick wax
Old 07-18-2016, 08:37 AM
  #6477
the flyin' scotsman
the flyin' scotsman's Avatar
Nice work Bertrand.........I would have installed new 53 type relays; cheap insurance
Old 07-18-2016, 09:00 AM
  #6478
Bertrand Daoust
Thanks Malcolm.
You're right.
I Wonder why I didn't change all of them last year when I changed the one for the X-Bus, starter, EZK, LH and fuel pump... ??
I'll put the others on my next parts order!
Old 07-19-2016, 09:07 AM
  #6479
docmac
docmac's Avatar
Default if i could find one...
I'm trying to locate a front abs sensor for my early 86 928. Porsche discontinued manufacturing them and from Ontario Canada out to san diego....can't seem to locate one. any suggestions ?
Old 07-20-2016, 10:24 PM
  #6480
OTR18WHEELER
You can call me Otis
OTR18WHEELER's Avatar
I washed it, and then took these pics today.
Quick Reply: So what did you do to your 928 Today......
