928 Forum 1978-1995
Sponsored by: 928 Specialists
So what did you do to your 928 Today......
Old 12-03-2015, 06:37 AM
  #6181
MainePorsche
MainePorsche's Avatar
Originally Posted by FLYVMO
Figured it would be cheaper to get the Nivea skin/seat cream in Germany. I was right, $4.00 per jar versus $15.00 in the US. It only took 24,000 gallons of fuel to get them
Cheers!
Carl
Got the German Nivea from a SoCal at 8$ per tin.
Old 12-06-2015, 02:40 PM
  #6182
pinballplanet
pinballplanet's Avatar
Put silicone oil in the cooling fan clutch. I used 5,000 cst from the hobby store. Somewhat frustrating trying to add drop by drop using the well documented heat and spin method. But then I tried loading up a syringe and squirting it in. Once in, I spun the fan until the trapped air in the clutch was able to escape into the syringe. Much faster this way. Then I was back on the road doing some holiday shopping.
Old 12-06-2015, 08:29 PM
  #6183
The Deputy
The Deputy's Avatar
Motor mounts are done...oil pan is now above cross member.
So, I did a little electrical work today.
Brian.
Old 12-07-2015, 12:36 AM
  #6184
Chalkboss
Chalkboss's Avatar
Dropped in a new CSF radiator I got from Rog. Damn, this thing is a piece of art. Easy peasy, no issues. Fit like a glove. Just need three new stickers for the top. That old Behr is a joke in comparison. Very pleased with purchase and cooling performance so far. Behr can sit in the corner and see how it's done.
Old 12-07-2015, 02:01 AM
  #6185
MainePorsche
Felt the same way when I put my CSF in. No seals to leak from.
Old 12-07-2015, 08:42 PM
  #6186
Petza914
Petza914's Avatar
Received 6,462 Likes on 4,118 Posts
Default Installed custom floor mats
Installed a full set of Inpelle custom leather floor mats with CF heel pad
Old 12-07-2015, 09:18 PM
  #6187
Chuck Schreiber
Chuck Schreiber's Avatar
Like those pedals!!
  #6188
MjRocket
MjRocket's Avatar
Ok..Do tell, where did you get the leather mats and what did they run you?
They look Great!
Old 12-07-2015, 09:45 PM
  #6189
Petza914
Petza914's Avatar
Originally Posted by Chuck Schreiber
Like those pedals!!
Thanks MJ. They're from SRP and they have a bunch of different textures and finishes available. Very nice quality. One of last year's Christmas gifts
Old 12-12-2015, 10:36 PM
  #6190
Ed Petry
Ed Petry's Avatar
Default Drove the car
Hi everyone,
The car is moving under its own power for the first time in 5+ years. Battled sour fuel in the system, bad tranny(5speed) [input sheared off], bad torque tube(splines gone), and all the other small problems associated with restarting a damaged car after a while in storage.
Just fun to drive...
Ed
Old 12-12-2015, 11:03 PM
  #6191
MainePorsche
Missed my car and garage again today.
Far from home. Haven't worked on or driven the car for many months now.
Old 12-16-2015, 10:03 PM
  #6192
NC928S4
NC928S4's Avatar
Replaced Rear Hatch Release Motor that I received from brother Herman. Works like a champ.
I have my original Motor that has the classic blown diode that I will gladly ship to anyone who wants to repair it. Motor works fine but never stops because diode is burnt.
I'm more of a Metric Hammer and Wrench guy and absolutely horrible with a soldering iron. Let me and I'll ship it for free because these units are very difficult to find.
Old 12-16-2015, 10:22 PM
  #6193
the flyin' scotsman
the flyin' scotsman's Avatar
I went to my storage location and made sure my GTS was all snugged up. Fortunate to have her in underground secure heated garage.
she is fine but sadly itll be a number of months before she moves again.
Old 12-16-2015, 10:57 PM
  #6194
SwedeInSiam
SwedeInSiam's Avatar
Had the AC system flushed and filled with R12 (still made and available cheap in Asia).
Now blows freezing cold, a good thing in a tropical country
Old 12-19-2015, 09:54 AM
  #6195
UKKid35
UKKid35's Avatar
Made use of the bizarrely warm UK weather and took the car outside for a coolant change. Things I learnt include
  • The block plugs were still a little awkward to break free despite still having plenty of Copperease on the threads
  • However hard you try to avoid it the coolant will get in your eyes and mouth
  • Removing the lower rad hose is not trivial either, and resulted in coolant running all the way along my arm to my armpit, nice
  • It is very easy to refill the cooling system if you remove the rad breather and fill it using a small funnel, it took no time to get 3L in to the rad
  • I'm on my fourth pressure switch and it has started leaking again
  • My rad is weeping slightly perhaps from one of the end tanks
  • I really need to find a replacement radiator upper mount, including the bracket that is spot welded to the inner wing, because mine is missing
  • It's very reassuring when the old coolant looks no different to the new
Quick Reply: So what did you do to your 928 Today......
